[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule <rulename>': null
Hi there!
Currently I’m looking for errors in my openhab.log to track down anything which does not belong there – for eliminating another problem.
I see errors like
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Determine number of activated lights': null
during regular operation.
Here’s my rule which is causing this behavior. I use this rules to prepare charting of active light counts (afaik there’s no way to get a Group:Switch into a chart).
import org.eclipse.xtext.xbase.lib.Functions
val Functions$Function2<GroupItem, GroupItem, Boolean> updateNumberItem= [ groupItem, associationGroup |
    val groupItemName = groupItem.name
    logInfo("counters", "updateNumberItem=" + groupItemName)
    val numberItemName = "I" + groupItemName.substring(1)
    val numberItem = associationGroup.members.findFirst[ ni | ni.name == numberItemName ]
    var count = groupItem.allMembers.filter(l|(l.state > 0 || l.state==ON)).size
    logInfo("counters", "update to " + numberItem.name + " for group " + groupItem.name + ": " + count)
    numberItem.postUpdate(count)
    true
rule "Determine number of activated lights"
    Item GlightsSfCounter received update or
    Item GlightsSfWrCounter received update or
    Item GlightsSfBarCounter received update or
    Item GlightsSfLrCounter received update or
    Item GlightsSfBerCounter received update or
    Item GlightsSfCorCounter received update or
    Item GswitchablesSfCounter received update or
    Item GswitchablesSfWrCounter received update or
    Item GswitchablesSfBerCounter received update
    logInfo("counters", "rule execution")
    logInfo("counters", "rule execution: item=" + triggeringItem.name)
    val triggeringGroup = (triggeringItem as GroupItem)
    updateNumberItem.apply(triggeringGroup, GassociatedCounters)
To get an understanding what happens when I execute the rule, here’s an excerpt of the openhab.log:
2018-07-15 15:25:39.494 [INFO ] [clipse.smarthome.model.script.motion] - No more motion in second floor living room: switching lights off
2018-07-15 15:25:39.536 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-15 15:25:39.542 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-15 15:25:39.556 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfLrCounter
2018-07-15 15:25:39.561 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfCounter
2018-07-15 15:25:39.573 [INFO ] [ipse.smarthome.model.script.counters] - updateNumberItem=GlightsSfCounter
2018-07-15 15:25:39.573 [INFO ] [ipse.smarthome.model.script.counters] - updateNumberItem=GlightsSfLrCounter
2018-07-15 15:25:39.665 [INFO ] [ipse.smarthome.model.script.counters] - update to IlightsSfLrCounter for group GlightsSfLrCounter: 0
2018-07-15 15:25:39.706 [INFO ] [ipse.smarthome.model.script.counters] - update to IlightsSfCounter for group GlightsSfCounter: 0
2018-07-15 15:25:49.603 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-15 15:25:49.614 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfLrCounter
2018-07-15 15:25:49.607 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-15 15:25:49.621 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfCounter
2018-07-15 15:25:49.634 [INFO ] [ipse.smarthome.model.script.counters] - updateNumberItem=GlightsSfLrCounter
2018-07-15 15:25:49.634 [INFO ] [ipse.smarthome.model.script.counters] - updateNumberItem=GlightsSfCounter
2018-07-15 15:25:49.656 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Determine number of activated lights': null
2018-07-15 15:25:49.679 [INFO ] [ipse.smarthome.model.script.counters] - update to IlightsSfLrCounter for group GlightsSfLrCounter: 0
I read [SOLVED] Error: Rule '<rulename>': null - #56 by yetkin and grasped that I should use the triggeringItem which I now did.
Can this be a concurrency issue? (Only speculation since I do not have yet a decent understanding about how openHAB works internally)
Almost always null errors are caused by type problems. This means you are trying to use an Object in a way that is not valid for that type of Object. Most of the time this is caused by , for example, trying to do a comparison operator with an Item’s whose state is NULL.
I’d be willing to bet that one of your members of groupItem is NULL which means l.state > 0 is an error.
Sorry for the late reply, I can only work on my home automation on weekends…
The group GassociatedCounters consists of static items only, as well as the groups in the triggeringItem, so I wonder how they could be null. I’ve now implemented a check for invalid casts by verifying groupItem !== null.
But I think I’m missing your point. I stumbled about Is there a difference between null and NULL?.
I guess you mean that
does not work in all cases. Do you say it will fail if state is NULL? Should it be like this:
var count = groupItem.allMembers.filter(l|((l.state != NULL) && (l.state > 0 || l.state==ON))).size
Yes, that is what I meant. NULL is a special state, not to be confused with null which is different, and that state doesn’t support the > operation.
I tried to fix it that way, but I’m still getting these null errors. Maybe there’s another reason? Perhaps something concurrency related?
Can you judge from the following log paired with the code?
2018-07-21 12:12:55.085 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-21 12:12:55.096 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfWrCounter
2018-07-21 12:12:55.106 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-21 12:12:55.109 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 1=GlightsSfWrCounter
2018-07-21 12:12:55.115 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfCounter
2018-07-21 12:12:55.119 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 2=GlightsSfWrCounter
2018-07-21 12:12:55.124 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 1=GlightsSfCounter
2018-07-21 12:12:55.116 [INFO ] [ipse.smarthome.model.script.counters] - update to IlightsSfWrCounter for group GlightsSfWrCounter: 0
2018-07-21 12:12:55.129 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 2=GlightsSfCounter
2018-07-21 12:12:55.137 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 3=GlightsSfCounter
2018-07-21 12:12:55.136 [INFO ] [ipse.smarthome.model.script.counters] - rule execution
2018-07-21 12:12:55.140 [INFO ] [ipse.smarthome.model.script.counters] - rule execution: item=GlightsSfCounter
2018-07-21 12:12:55.136 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 3=GlightsSfWrCounter
2018-07-21 12:12:55.148 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 1=GlightsSfCounter
2018-07-21 12:12:55.149 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Determine number of activated items': null
2018-07-21 12:12:55.154 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 2=GlightsSfCounter
2018-07-21 12:12:55.162 [INFO ] [marthome.model.script.counters-debug] - updateNumberItem 3=GlightsSfCounter
2018-07-21 12:12:55.175 [INFO ] [ipse.smarthome.model.script.counters] - update to IlightsSfCounter for group GlightsSfCounter: 0
2018-07-21 12:12:55.179 [INFO ] [ipse.smarthome.model.script.counters] - update to IlightsSfWrCounter for group GlightsSfWrCounter: 0
… and the rules:
    if (groupItem !== null) {
        logInfo("counters-debug", "updateNumberItem 1=" + groupItemName)
        logInfo("counters-debug", "updateNumberItem 2=" + groupItemName)
        val numberItem = associationGroup.members.findFirst[ ni | (ni.name != NULL) && (ni.name == numberItemName) ]
        logInfo("counters-debug", "updateNumberItem 3=" + groupItemName)
    true
rule "Determine number of activated items"
It can be a concurrency issue. When you trigger using received update on a group, the rule triggers n-1 times for every single update to one of its members, where n is the number of members.
So if the Group has five members, this role will trigger 4 times all within milliseconds of each other when one Item changes.
You don’t say how you defined these Groups but if all you need is the number of ON Items, you don’t need any rules at all.
Group:Number:SUM
With this the Group’s state will be the number of its members that are ON. No rules required.
At a minimum you should use the Member of rule trigger so the rule only triggers once per change.
Do you see a way how such a concurrency issue could cause that behavior?
But let me show you how I defined the groups:
Group:Number:SUM GlightsSfCounter "Lichter aktiv [%d]" <light> (Gsf)
Group:Switch:OR(ON, OFF) GlightsSfWrCounter "Lichter aktiv [%d]" <light> (GlightsSfCounter)
Group:Switch:OR(ON, OFF) GlightsSfBarCounter "Lichter aktiv [%d]" <light> (GlightsSfCounter)
Group:Switch:OR(ON, OFF) GlightsSfLrCounter "Lichter aktiv [%d]" <light> (GlightsSfCounter)
Group:Switch:OR(ON, OFF) GlightsSfLrSideboardCounter "Lichter aktiv [%d]" <light> (GlightsSfLrCounter)
Group:Switch:OR(ON, OFF) GlightsSfBerCounter "Lichter aktiv [%d]" <light> (GlightsSfCounter)
Group:Switch:OR(ON, OFF) GlightsSfCorCounter "Lichter aktiv [%d]" <light> (GlightsSfCounter)
Group:Switch:OR(ON, OFF) GlightsSfSrCounter "Lichter aktiv [%d]" <light> (GlightsSfCounter)
You’re saying that I don’t need this logic, but I did not find any other way around it. as within the BasicUI the groups are usable to show the active light counts, but I cannot use the values for charting. In order to persist active light counts, I had to update the items. – Is there another way to achieve this?
Best regards!
I have similar error, but instead of null, it’s written 4 :
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'RFLink IN': 4
What is the meaning of 4? What I should looking for into my rule RFLink IN?
There is the rule triggering this error:
rule "RFLink IN"
   Item RFLinkRaw received update
logInfo(logName, "raw data received: " + RFLinkRaw.state)
// split the message into parts on the ';'
val RFbuffer = RFLinkRaw.state.toString.split(';')
//	val RFprefix = RFbuffer.get(0)
//	val RFstamp = RFbuffer.get(1)
val RFvendor = RFbuffer.get(2)
val RFidLong = RFbuffer.get(3)
val RFdata_1 = RFbuffer.get(4)
val RFdata_2 = RFbuffer.get(5)
val RFidHex = transform("REGEX", "ID=([0-9a-fA-F]*)", RFidLong)
// look at the fifth part of the message to see which type of message it is and parse accordingly
switch (RFvendor + " " + RFidHex) {
    // process a TEMP message
    case "LacrosseV4 0001" : { //sonde Lacrosse extérieure
    	val tempHex = RFdata_1.replace("TEMP=", '')
        val rawTemp = new java.math.BigDecimal(Integer::parseInt(tempHex, 16))
        val adjustedNegTemp = (rawTemp-32768)/-10.0
        val adjustedPosTemp = rawTemp / 10.0
        if (rawTemp > 32768) {
        	Lacrosse_OUT_Temperature.postUpdate(adjustedNegTemp)
        	logInfo(logName, "some data received from " + RFvendor + ":Temp=" + adjustedNegTemp + "C" )
        else {
        	Lacrosse_OUT_Temperature.postUpdate(adjustedPosTemp)
        	logInfo(logName, "some data received from " + RFvendor + ":Temp=" + adjustedPosTemp + "C" )
// process a RollerShutter message
switch (RFvendor) {
    case "BrelMotor" : {
		switch (RFdata_1) {
			case ("SWITCH=05") : {
				logInfo(logName, "Command confirmation from " + RFvendor + " chambre:" + RFdata_2)
			case ("SWITCH=a0") : {
				logInfo(logName, "Command confirmation from " + RFvendor + " All living:" + RFdata_2)
			case ("SWITCH=a1") : {
				logInfo(logName, "Command confirmation from " + RFvendor + " Living1:" + RFdata_2)
			case ("SWITCH=a2") : {
				logInfo(logName, "Command confirmation from " + RFvendor + " Living2:" + RFdata_2)
			case ("SWITCH=a3") : {
				logInfo(logName, "Command confirmation from " + RFvendor + " Living3:" + RFdata_2)
			case ("SWITCH=a4") : {
				logInfo(logName, "Command confirmation from " + RFvendor + " Living4:" + RFdata_2)
			default : logInfo(logName, "completely irrelevant data received from " + RFvendor)
	case "LacrosseV4" : {
Wild guess that is your culprit. The unhelpful message is sometimes due to array index being out of range.
I would modify your rule to see if the array resulting from the message split is as long as you expected.
I see… You are perfectly right. When I received RF data from my devices, it fit all the buffer. After sending information to take action, confirmation received from device is only 3 bytes…
2020-06-29 08:00:01.325 [INFO ] [e.smarthome.model.script.RFLinkLogMM] - raw data received: 20;B3;OK;
2020-06-29 08:00:01.336 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'RFLink IN': 4
My understanding is that isn’t causing any issue but that error log. Is there a way to manage that kind of data not always of the same length?
Yes of course.
Your array-of-strings variable RFbuffer has a length property, to tell you how long it is.
if ( RFbuffer.length > 5) {
   // do stuff
} else {
   // short message, do something else
Problem fixed. Thanks a lot!
 // Do something only if RFbuffer have at least 5 bytes. If I received 3 bytes, it's an acknowledge message, exit.
if (RFbuffer.length < 5) {
	return;
else {
    // Do normal stuff
Note that, if your message happens to be 5 elements long,
will still error because it counts elements from 0, (5) is the sixth element.
Good point. Thanks. I’ll make modification.
Hello, I have a similar case I can not solve since a few weeks now:-(
My rule is short as follows:
rule "Wind direction & speed" //combine wind speed & wind direction into one item
    Member of gWind changed
    var wdir = gWind.members.findFirst[ t | t.name == ("OWM_"+ triggeringItem.name.split("_").get(1) + "_WindDirection") ]
    var wspeed = gWind.members.findFirst[ t | t.name == ("OWM_"+ triggeringItem.name.split("_").get(1) + "_WindSpeed") ]
gOWM.members.findFirst[ t | t.name == ("OWM_"+ triggeringItem.name.split("_").get(1) + "_WindSpeedDirection") ].postUpdate((wspeed.state.toString) + " [" + transform("SCALE", "wind.scale", (wdir.state as QuantityType<Number>).doubleValue.toString) +"]")
//    gOWM.members.findFirst[ t | t.name == ("OWM_"+ triggeringItem.name.split("_").get(1) + "_WindSpeedDirection") ].postUpdate((wspeed.state.toString.split(".").get(0)) + "km/h [" + transform("SCALE", "wind.scale", (wdir.state as QuantityType<Number>).doubleValue.toString) +"]")
From the user’s point of view, the combined elements of wind speed & wind direction are displayed as one item correctly in Basic UI. However there are errors (somtimes more than one, somtimes/rare no errors) in logs:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Wind direction & speed': null
I also tested a different version of this rule (the last line of the rule in the comment trying to present speed as integer) but the error is:
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Wind direction & speed': 0
Any hints where to search for source of this error?
Actually it’s not really short. there is a whole lot of stuff going on in that last line of code.
To have any hope of finding what part of that line is generating the error you will have to break it up. Generate the item names on it’s own line and log to see it’s correct. Put the find first on it’s own line and verify it found the item. Put the transform on it’s own line and log that it returns something. And so on. This should tell you where the error will come from.
Following your advice I have simplified the rule for testing purposes as follows:
logInfo("TEST", wdir.name.toString + "  " + wdir.state.toString)
logInfo("TEST", wspeed.name.toString + "  " + wspeed.state.toString)
    val test = gOWM.members.findFirst[ t | t.name == ("OWM_"+ triggeringItem.name.split("_").get(1) + "_WindSpeedDirection") ]
logInfo("TEST", test.name.toString + "  " + test.state.toString)
// gOWM.members.findFirst[ t | t.name == ("OWM_"+ triggeringItem.name.split("_").get(1) + "_WindSpeedDirection") ].postUpdate((wspeed.state.toString) + " [" + transform("SCALE", "wind.scale", (wdir.state as QuantityType<Number>).doubleValue.toString) +"]")
gWind includes OWM_XX_WindSpeed and OWM_XX_WindDirection items which can trigger the rule. My assumption is that if both XX items have changed the rule shall be triggered twice providing value for wdir, wspeed, test for each trigerringItem.
I think that null error is caused by val test (searching for item in gOWM group which is bigger). Sometimes OWM_XX_WindSpeedDirection is found/reported only one time despite that both items OWM_XX_WindSpeed and OWM_XX_WindDirection have changed.
For instance (based on logs attached below): OWM_24_WindDirection and OWM_24_WindSpeed Items changed I can see two lines with OWM_24_WindSpeedDirection 10.296 km/h [N] .
However for OWM_48_WindSpeed and OWM_48_WindDirection items changed there is only one line with OWM_48_WindSpeedDirection 12.204 km/h [ESE], then null error reported.
2020-08-13 09:37:46.742 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_00_WindDirection  250.0 °
2020-08-13 09:37:46.757 [vent.ItemStateChangedEvent] - OWM_00_WindSpeed changed from 3.6 km/h to 7.56 km/h
2020-08-13 09:37:46.765 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_00_WindSpeed  7.56 km/h
2020-08-13 09:37:46.838 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_00_WindDirection  250.0 °
2020-08-13 09:37:46.857 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_00_WindSpeed  7.56 km/h
2020-08-13 09:37:46.890 [vent.ItemStateChangedEvent] - OWM_00_WindDirection changed from 0.0 ° to 250.0 °
2020-08-13 09:37:46.963 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_06_WindDirection  294.0 °
2020-08-13 09:37:46.990 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_06_WindSpeed  2.628 km/h
2020-08-13 09:37:46.997 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Wind direction & speed': null
2020-08-13 09:37:47.110 [vent.ItemStateChangedEvent] - OWM_06_WindSpeed changed from 4.968 km/h to 2.628 km/h
2020-08-13 09:37:47.112 [vent.ItemStateChangedEvent] - OWM_06_WindDirection changed from 284.0 ° to 294.0 °
2020-08-13 09:37:47.120 [vent.ItemStateChangedEvent] - OWM_12_Temperature changed from 22.66 °C to 22.97 °C
2020-08-13 09:37:47.122 [vent.ItemStateChangedEvent] - OWM_12_WindSpeed changed from 11.268 km/h to 11.196 km/h
2020-08-13 09:37:47.129 [vent.ItemStateChangedEvent] - OWM_12_WindDirection changed from 50.0 ° to 53.0 °
2020-08-13 09:37:47.174 [vent.ItemStateChangedEvent] - OWM_24_WindSpeed changed from 8.208 km/h to 9.324 km/h
2020-08-13 09:37:47.177 [vent.ItemStateChangedEvent] - OWM_24_WindDirection changed from 130.0 ° to 122.0 °
2020-08-13 09:37:47.190 [vent.ItemStateChangedEvent] - OWM_48_WindSpeed changed from 12.996 km/h to 11.952 km/h
2020-08-13 09:37:47.193 [vent.ItemStateChangedEvent] - OWM_48_WindDirection changed from 103.0 ° to 122.0 °
2020-08-13 09:37:47.313 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_00_WindSpeedDirection  5.4 km/h [NNW]
2020-08-13 09:37:47.325 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_06_WindDirection  294.0 °
2020-08-13 09:37:47.334 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_06_WindSpeed  2.628 km/h
2020-08-13 09:37:47.489 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_12_WindDirection  53.0 °
2020-08-13 09:37:47.497 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_12_WindSpeed  11.196 km/h
2020-08-13 09:37:47.525 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_06_WindSpeedDirection  9.288 km/h [ESE]
2020-08-13 09:37:47.668 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_06_WindSpeedDirection  9.288 km/h [ESE]
2020-08-13 09:37:47.708 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_12_WindDirection  53.0 °
2020-08-13 09:37:47.714 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_12_WindSpeed  11.196 km/h
2020-08-13 09:37:47.739 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_24_WindDirection  122.0 °
2020-08-13 09:37:47.750 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_24_WindSpeed  9.324 km/h
2020-08-13 09:37:47.850 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Wind direction & speed': null
2020-08-13 09:37:47.890 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_24_WindDirection  122.0 °
2020-08-13 09:37:47.898 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_24_WindSpeed  9.324 km/h
2020-08-13 09:37:48.136 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_12_WindSpeedDirection  4.248 km/h [ESE]
2020-08-13 09:37:48.259 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_24_WindSpeedDirection  10.296 km/h [N]
2020-08-13 09:37:48.268 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_48_WindDirection  122.0 °
2020-08-13 09:37:48.273 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_48_WindSpeed  11.952 km/h
2020-08-13 09:37:48.326 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_24_WindSpeedDirection  10.296 km/h [N]
2020-08-13 09:37:48.361 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_48_WindDirection  122.0 °
2020-08-13 09:37:48.366 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_48_WindSpeed  11.952 km/h
2020-08-13 09:37:48.376 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Wind direction & speed': null
2020-08-13 09:37:48.540 [INFO ] [.eclipse.smarthome.model.script.TEST] - OWM_48_WindSpeedDirection  12.204 km/h [ESE]
So based on the logs there are no second lines for: OWM_00_WindSpeedDirection, OWM_12_WindSpeedDirection and OWM_48_WindSpeedDirection and there 3 null errors
Seems the null error is not a specific item related. All items are defined in the same way and the error is random. I mean in the attached log there is one line only with OWM_00_WindSpeedDirection (the second line I assume is the error), but in the other logs (another time) OWM_00_WindSpeedDirection has two lines.
Seems like an instance of rule tries to find an item (in a bigger group) and the same time another instance of this rule tries to find the same item and there is some sort a conflict in accessing/find and assign the same item?
i would understand it more as a failure to retrieve group members while a simultaneous update is going on. (The OH framework Group machinery churns around on update, not just on change)
Assuming you have more or less simultaneous updates to your two Items that are members of the same group.
Simple circumvention, add a 100mS sleep at front of your rule to allow updates to complete.
I think a more efficient method would be just to check for null after searching group, and just exit rule tidily if null seen. There’ll be another update (another rule trigger) along in a moment. EDIT - maybe not, as you trigger on change. Just the delay then.
The OWM update triggers the rule every hour.
I have applied Thread::sleep(500) and also reduced by ~20 Items in the gOWM group.
But those did not eliminate the error completelly. It appears if more/all items in the gOWM group are updated.
But I can live with it as it does not affect the presented data in Basic UI
The error wouldn’t occur if you’d use ScriptServiceUtil to get the Item…
