resolution of uriFragment ‘|::0.2.0.2.0.0.0.6.6::0::/1’ failed.
This is my new rule. As soon as the BOLD part is uncommented, i get this error. If i comment it out, no error.
This kind of Logic (including item and sitemap) is already in use and working.
Filename: tagesmodus.rules (i copied an existing rule, renamed and replaced content)
rule “r_Tagesmodus_1”
Item i_v_Tagesmodus changed
if(i_v_Tagesmodus.state==4)
{ i_v_Tagesmodus.postUpdate(100)
items:
Number i_v_Tagesmodus
Switch i_v_Tagesmodus_Auto_Aktiv
Any guess what this could be?
This is the working one
rule “r_1OG_Wohnzimmer_Beschattung_Gesamt_1”
Item i_v_Beschattung_Wohnzimmer_Gesamt changed
if(i_v_Beschattung_Wohnzimmer_Gesamt.state==1)
i_v_Beschattung_Wohnzimmer_Gesamt.postUpdate(100)
The working rule was created before update to 2.5.3. I dont see any differences between the working one (created before update to 2.5.3) and the new one giving the error (created after update to 2.5.3)
Did you ever find the reason for this behaviour? I have the same error. But It just started with OpenHAB so I assume a fresh install will not really make any difference (just installed it three days ago…).
As soon as I try to "Schalter_EG.sendCommand(ON) I am getting this Nul Pointer Exception, just aas you.
I couldnt find out, but after a fresh install it worked again.
In your case i anyway would give it a try, do a fresh install and maybe first do a test by just adding what you need to send this command (only one thing, only this single item and this single rule).
For me, it was important to take fresh emtpy folders and just put the files (things, items, sitemap, rules) back in.
you mean a complete new start with a new SD_card image?
That’s a lot of work!
I recently got this error as well, but will try with clean cache and multiple restarts first.
Same error here. Started today…everything seems to be working, but logs are flooded with this. Did anyone find a fix? Apart from reinstalling everything…
