Hi guys,
I’m trying to get my Easybulb lights running with openHAB and in the next step with the Amazon Echo. As an initial step I need to get the Eclipse SmartHome Designer running on my iMac (Mac OS Sierra running on it). Therefore I downloaded and installed the “jdk-8u111-macosx-x64” and the “jre-8u111-macosx-x64”. First one is for getting the OpenHAB2 running, which works fine. Second one is , as far as I understood, needed for the Eclipse SmartHome App.
Right now, I have the issue that the Eclipse app is not starting up with almost the same error desrcibed from sillyfrog:
!SESSION 2016-12-29 12:37:53.800 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_111
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE
Command-line arguments: -os macosx -ws cocoa -arch x86_64
!ENTRY org.eclipse.core.runtime 4 0 2016-12-29 12:37:54.480
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.core.runtime [2]
Unresolved requirement: Require-Bundle: javax.annotation; bundle-version=“1.1.0”; visibility:=“reexport”; resolution:=“optional"
Unresolved requirement: Require-Bundle: javax.inject; bundle-version=“1.0.0”; visibility:=“reexport”; resolution:=“optional"
Unresolved requirement: Require-Bundle: org.eclipse.equinox.common; bundle-version=”[3.6.100,4.0.0)”; visibility:=“reexport”
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:242)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:172)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:412)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:320)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:232)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
and
!ENTRY org.eclipse.osgi 4 0 2016-12-29 12:38:08.072
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: The platform metadata area could not be written: /private/var/folders/x_/y5dfxwpn00318lwnc9wfbb640000gp/T/AppTranslocation/9FE66F3F-4908-4E05-9C46-14EEF43323DD/d/Eclipse SmartHome Designer.app/Contents/MacOS/workspace/.metadata. By default the platform writes its content
under the current working directory when the platform is launched. Use the -data parameter to
specify a different content area for the platform.
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:61)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:129)
at org.eclipse.core.internal.preferences.InstancePreferences.getBaseLocation(InstancePreferences.java:44)
at org.eclipse.core.internal.preferences.InstancePreferences.initializeChildren(InstancePreferences.java:199)
at org.eclipse.core.internal.preferences.InstancePreferences.(InstancePreferences.java:59)
at org.eclipse.core.internal.preferences.InstancePreferences.internalCreate(InstancePreferences.java:209)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:391)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:379)
at org.eclipse.core.internal.preferences.PreferencesService.createNode(PreferencesService.java:389)
at org.eclipse.core.internal.preferences.RootPreferences.getChild(RootPreferences.java:63)
at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:101)
at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:90)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.InstanceScope.getNode(InstanceScope.java:80)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getStorePreferences(ScopedPreferenceStore.java:244)
at org.eclipse.ui.preferences.ScopedPreferenceStore.(ScopedPreferenceStore.java:133)
at org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(AbstractUIPlugin.java:285)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:593)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.smarthome.designer.ui.internal.application.Application.start(Application.java:32)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
I googled about this issue, but found not really a solution for this or I did not understand fully the handling of this issue.
As I understand the two exceptions:
First one says that there some bundles requires !? Where or how to get them?
Second exception tells the same like sillyfrog described. The sandboxing topic…
Additional information:
I do not have the Eclipse SmartHome in the download folder.
Any suggestions what to do and what more infos are neede to have a closer look at this problem?
BR
McSaesh
