Error starting karaf activator
Using openHAB 2.5_M4
I try using binding FritzBox TR064 - don’t get it working and the first errors seem to be related to this. Currently, this binding is not installed.
Java Versions:
openjdk version “9-Raspbian”
OpenJDK Runtime Environment (build 9-Raspbian+0-9b181-4bpo9rpt1)
OpenJDK Server VM (build 9-Raspbian+0-9b181-4bpo9rpt1, mixed mode)
javac 1.8.0_65
The file
/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.specs.activator-4.2.6.jar
exists and is owned by openhab
2019-11-17 14:51:34.705 [WARNUNG] [org.apache.karaf.main.KarafActivatorManager] - Error starting karaf activator org.apache.karaf.specs.activator.Activator from url jar:file:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.specs.activator-4.2.6.jar!/META-INF/MANIFEST.MF
java.lang.NoClassDefFoundError: org/apache/karaf/specs/locator/OsgiLocator
at org.apache.karaf.specs.activator.Activator.register(Activator.java:124)
at org.apache.karaf.specs.activator.Activator.start(Activator.java:71)
at org.apache.karaf.main.KarafActivatorManager.startKarafActivators(KarafActivatorManager.java:62)
at org.apache.karaf.main.Main.launch(Main.java:281)
at org.apache.karaf.main.Main.main(Main.java:178)
Caused by: java.lang.ClassNotFoundException: org.apache.karaf.specs.locator.OsgiLocator
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:582)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:185)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
… 5 more
This is the error log with the binding installed:
2019-11-17 16:22:28.846 [WARN ] [org.openhab.binding.fritzboxtr064 ] - FrameworkEvent WARNING - org.openhab.binding.fritzboxtr064
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.obtain(EventHandlerProxy.java:286) ~[?:?]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:407) ~[?:?]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.runWithoutBlacklistTiming(HandlerTask.java:82) ~[?:?]
at org.apache.felix.eventadmin.impl.tasks.SyncDeliverTasks.execute(SyncDeliverTasks.java:104) ~[?:?]
at org.apache.felix.eventadmin.impl.tasks.AsyncDeliverTasks$TaskExecuter.run(AsyncDeliverTasks.java:166) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:514) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641) ~[?:?]
at java.lang.Thread.run(Thread.java:844) ~[?:?]
Can someone help me make this running?
Switched to M5.
Error Log on M5:
2019-11-20 17:42:11.489 [ERROR] [org.openhab.binding.fritzboxtr064 ] - bundle org.openhab.binding.fritzboxtr064:1.14.0.M5 (236)[org.openhab.binding.fritzboxtr064.binding(26)] : The activate method has thrown an exception
java.lang.NoClassDefFoundError: javax/xml/soap/SOAPElement
at org.openhab.binding.fritzboxtr064.internal.FritzboxTr064Binding.activate(FritzboxTr064Binding.java:153) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:564) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
at java.security.AccessController.doPrivileged(Native Method) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [bundleFile:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:825) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:767) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) [bundleFile:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1153) [bundleFile:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1036) [bundleFile:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) [bundleFile:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) [bundleFile:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641) [?:?]
at java.lang.Thread.run(Thread.java:844) [?:?]
Caused by: java.lang.ClassNotFoundException: javax.xml.soap.SOAPElement cannot be found by org.openhab.binding.fritzboxtr064_1.14.0.M5
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[org.eclipse.osgi-3.12.100.jar:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:496) ~[?:?]
… 100 more
2019-11-20 17:42:11.587 [ERROR] [org.openhab.binding.fritzboxtr064 ] - bundle org.openhab.binding.fritzboxtr064:1.14.0.M5 (236)[org.openhab.binding.fritzboxtr064.binding(26)] : The activate method has thrown an exception
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:756) [bundleFile:?]
… 72 more
My assumption is that
is your problem.
You need a Java 8 for openHAB and OpenJDK is currently not recommended. See Installation Overview | openHAB for details.
Ok. Changed to zulu.
At first glance, it made it. Some things work that did not before.
Thank you a lot!
Still I have some error messages, but I’ll do my homework first and search through the forum if I can fix it myself.
