Error: Unable to execute HTTP request: after upgrade from 3.2.0 to 3.3.0 M7
Dear OpenHAB Developers
I just updated my system from the stable release 2.3 to M7 3.3 and all http requests don’t work anymore, see the following error message. Due to the fact that I’m not able to downgrade properly the system, I would appreciate a fix of this problem a lot. I already try to restart and remove re-created the container, but the error persists. Attached the log of the update
openHab_update.log (6.6 KB)
Unable to execute HTTP request: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
Also the http request in my rules [enhab.core.model.script.actions.HTTP] doesn’t work any more
Openhab.log:
2022-06-22 22:35:29.805 [ERROR] [ity.CommunityMarketplaceAddonService] - Unable to retrieve marketplace add-ons
javax.net.ssl.SSLException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
	at sun.security.ssl.Alert.createSSLException(Alert.java:133) ~[?:?]
	at sun.security.ssl.TransportContext.fatal(TransportContext.java:353) ~[?:?]
	at sun.security.ssl.TransportContext.fatal(TransportContext.java:296) ~[?:?]
	at sun.security.ssl.TransportContext.fatal(TransportContext.java:291) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1689) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:471) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:427) ~[?:?]
	at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:572) ~[?:?]
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:197) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1592) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1520) ~[?:?]
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:250) ~[?:?]
	at org.openhab.core.addon.marketplace.internal.community.CommunityMarketplaceAddonService.getRemoteAddons(CommunityMarketplaceAddonService.java:172) ~[?:?]
	at org.openhab.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) ~[?:?]
	at org.openhab.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) ~[?:?]
	at org.openhab.core.addon.marketplace.AbstractRemoteAddonService.refreshSource(AbstractRemoteAddonService.java:110) ~[?:?]
	at org.openhab.core.addon.marketplace.internal.community.CommunityMarketplaceAddonService.modified(CommunityMarketplaceAddonService.java:128) ~[?:?]
	at org.openhab.core.addon.marketplace.internal.community.CommunityMarketplaceAddonService.<init>(CommunityMarketplaceAddonService.java:117) ~[?:?]
	at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
	at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
	at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
	at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
	at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:776) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1271) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1222) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:956) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:495) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) ~[osgi.core-7.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:944) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:486) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:464) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1160) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1041) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
	at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:102) ~[?:?]
	at sun.security.validator.Validator.getInstance(Validator.java:181) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.getValidator(X509TrustManagerImpl.java:300) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkTrustedInit(X509TrustManagerImpl.java:176) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:189) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:129) ~[?:?]
	at sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1341) ~[?:?]
	at sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(CertificateMessage.java:1232) ~[?:?]
	at sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(CertificateMessage.java:1175) ~[?:?]
	at sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392) ~[?:?]
	at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:443) ~[?:?]
	at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:421) ~[?:?]
	at sun.security.ssl.TransportContext.dispatch(TransportContext.java:183) ~[?:?]
	at sun.security.ssl.SSLTransport.decode(SSLTransport.java:172) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1506) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1416) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:456) ~[?:?]
	... 78 more
Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
	at java.security.cert.PKIXParameters.setTrustAnchors(PKIXParameters.java:200) ~[?:?]
	at java.security.cert.PKIXParameters.<init>(PKIXParameters.java:120) ~[?:?]
	at java.security.cert.PKIXBuilderParameters.<init>(PKIXBuilderParameters.java:104) ~[?:?]
	at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:99) ~[?:?]
	... 78 more
2022-06-22 22:35:30.416 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'CET'.
This also affect the following bindings which cant connect to the services:
PollyTTS:
022-06-22 22:37:12.819 [WARN ] [ce.pollytts.internal.PollyTTSService] - Failed to initialize PollyTTS com.amazonaws.SdkClientException: Unable to execute HTTP request: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
Tado Home Thing:
COMMUNICATION_ERROR
Could not connect to server due to Error calling https://auth.tado.com/oauth/token
Maybe it works better if you configure the container to use unlimited crypto, see:
Hi Wouter
Thank you for this reference. I just tried it out, but unfortunately it did not help…
The crypto police seems not to be the problem…
+ IFS='
++ ls -d /usr/lib/jvm/temurin-11-jdk-armhf
+ export JAVA_HOME=/usr/lib/jvm/temurin-11-jdk-armhf
+ JAVA_HOME=/usr/lib/jvm/temurin-11-jdk-armhf
+ '[' unlimited = unlimited ']'
+ echo 'Configuring Java unlimited strength cryptography policy...'
+ sed -i 's/^crypto.policy=limited/crypto.policy=unlimited/' /usr/lib/jvm/temurin-11-jdk-armhf/conf/security/java.security
I just tested this and it works fine on the amd64 image. However on the armhf image I do see such exceptions. Maybe it is caused by replacing Zulu with the Temurin JDK recently. I’ll have a closer look. :slightly_smiling_face::mag_right:
It seems that the Adoptium cacerts file in the armhf image is corrupt after installing the JDK.
Probably some issue due to the update not working properly when the images are build using emulation on amd64.
As a workaround you can fix it manually by running the /etc/ca-certificates/update.d/adoptium-cacerts script in the container:
# ls -l /etc/ssl/certs/adoptium/cacerts
-r--r--r-- 1 root root 32 Jun 19 20:43 /etc/ssl/certs/adoptium/cacerts
# /etc/ca-certificates/update.d/adoptium-cacerts
/etc/ssl/certs/adoptium/cacerts successfully populated.
-r--r--r-- 1 root root 148968 Jun 23 19:26 /etc/ssl/certs/adoptium/cacerts
Then it should work after restarting the container. :slight_smile:
I’ll check how to get it working properly.
Hi Wouter
First of all thank you for the closer look to this problem! I really do appreciate the support of the openHab community and of curse the technical knowledge of the maintainers!
The workaround did solve the problem of all the http requests. So let’s fix this in 3.3 stable release and hopefully the rest of the community who have similar issues can profit:
best regards
Nicolas
As a workaround for now I’ve added the command to update the certificates to the Debian container entrypoint. Upgrading the build tools for Docker didn’t seem to help. :face_with_diagonal_mouth:
It should be fixed in the latest Docker snapshot build as well as a new 3.3.0.M7 build. You can also wait for a few hours and then upgrade to 3.3.0.RC1 instead.
