Hey all,
my openhab began posting many errors from my networkupstoolsbinding… and the strangest thing is: the binding seems to work - all data of my usv is available.
But it spams my log and … i really would like to understand where this keeps coming from.
first of all the error:
2017-09-14 21:41:25.169 [ERROR] [ools.internal.NetworkUpsToolsBinding] - Nut processing error
[NutException]DRIVER-NOT-CONNECTED :
at org.networkupstools.jnut.Client.detectError(Client.java:407)[204:org.openhab.binding.networkupstools:1.10.0]
at org.networkupstools.jnut.Client.get(Client.java:503)[204:org.openhab.binding.networkupstools:1.10.0]
at org.networkupstools.jnut.Device.getVariable(Device.java:236)[204:org.openhab.binding.networkupstools:1.10.0]
at org.openhab.binding.networkupstools.internal.NetworkUpsToolsBinding.execute(NetworkUpsToolsBinding.java:102)[204:org.openhab.binding.networkupstools:1.10.0]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:157)[205:org.openhab.core.compat1x:2.1.0]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:169)[205:org.openhab.core.compat1x:2.1.0]
and
017-09-14 21:27:34.732 [ERROR] [ools.internal.NetworkUpsToolsBinding] - Nut processing error
java.net.ConnectException: Verbindungsaufbau abgelehnt (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)[:1.8.0_144]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)[:1.8.0_144]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)[:1.8.0_144]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)[:1.8.0_144]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_144]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_144]
at java.net.Socket.connect(Socket.java:538)[:1.8.0_144]
at java.net.Socket.<init>(Socket.java:434)[:1.8.0_144]
at java.net.Socket.<init>(Socket.java:211)[:1.8.0_144]
at org.networkupstools.jnut.StringLineSocket.connect(StringLineSocket.java:77)[204:org.openhab.binding.networkupstools:1.10.0]
at org.networkupstools.jnut.StringLineSocket.<init>(StringLineSocket.java:66)[204:org.openhab.binding.networkupstools:1.10.0]
at org.networkupstools.jnut.Client.connect(Client.java:208)[204:org.openhab.binding.networkupstools:1.10.0]
at org.networkupstools.jnut.Client.connect(Client.java:182)[204:org.openhab.binding.networkupstools:1.10.0]
at org.networkupstools.jnut.Client.<init>(Client.java:165)[204:org.openhab.binding.networkupstools:1.10.0]
at org.openhab.binding.networkupstools.internal.NetworkUpsToolsBinding.execute(NetworkUpsToolsBinding.java:98)[204:org.openhab.binding.networkupstools:1.10.0]
Most config is done on the nut inside my ubuntu-server and the binding connects there. The code of the service is:
# Refresh interval for state updates in milliseconds (optional)
refresh=10000
# UPS device name
ups1.device=APCX750
ups2.device=APC10K
# UPS server hostname (optional)
ups1.host=127.0.0.1
ups2.host=127.0.0.1
# UPS server port (optional)
ups1.port=3493
ups2.port=3493
# UPS server login (optional)
ups1.login=admin
ups2.login=admin
# UPS server pass (optional)
ups1.pass=[...]
ups2.pass=[...]
items file is:
/* APC in Erbstadt */
Number UpsErbstadt_BatteryRuntime "Batterie Laufzeit" { networkupstools="ups1:battery.runtime" }
Number UpsErbstadt_InputVoltage "Input Voltage" { networkupstools="ups1:input.voltage" }
Number UpsErbstadt_BatteryRuntimeLow "Batterie Laufzeit Low" { networkupstools="ups1:battery.runtime.low" }
Number UpsErbstadt_Temperature "Temperatur" { networkupstools="ups1:ups.temperature" }
Number UpsErbstadt_BatteryCharge "Battery Charge" { networkupstools="ups1:battery.charge" }
Number UpsErbstadt_Load "output voltage [%.1f V]" { networkupstools="ups1:ups.load" }
String UPS_APC_Erbstadt_Status "Status [%s]" { networkupstools="ups1:ups.status" }
String UPS_APC_Erbstadt_TestDatum "Testdatum" { networkupstools="ups1:ups.test.date" }
String UPS_APC_Erbstadt_TestErgebnis "Testergebnis" { networkupstools="ups1:ups.test.result" }
/* APC im Büro */
Number UpsRobertBosch_Temperature "Temperatur" { networkupstools="ups2:ups.temperature" }
Number UpsRobertBosch_BatteryRuntime "Batterie Laufzeit" { networkupstools="ups2:battery.runtime" }
Number UpsRobertBosch_InputVoltage "Input Voltage" { networkupstools="ups2:input.voltage" }
Number UpsRobertBosch_BatteryRuntimeLow "Batterie Laufzeit Low" { networkupstools="ups2:battery.runtime.low" }
Number UpsRobertBosch_BatteryCharge "Battery Charge" { networkupstools="ups2:battery.charge" }
Number UpsRobertBosch_Load "output voltage [%.1f V]" { networkupstools="ups2:ups.load" }
String UPS_APC_RobertBosch_Status "Status [%s]" { networkupstools="ups2:ups.status" }
and the nut-code is:
[APCX750]
driver = snmp-ups
mibs = apcc
desc = "APC AP9630"
port = [ip goes here]
snmp_version = v1
community = [community]
pollfreq = 30
[APC10K]
driver = snmp-ups
mibs = apcc
desc = "APC 10K"
snmp_version = v1
pollfreq = 30
Log-File events looks like:
2017-09-14 21:27:05.024 [ItemStateChangedEvent ] - UpsRobertBosch_Temperature changed from NULL to 29.0
2017-09-14 21:27:05.030 [ItemStateChangedEvent ] - UpsRobertBosch_BatteryRuntime changed from NULL to 2640.0
2017-09-14 21:27:05.034 [ItemStateChangedEvent ] - UpsRobertBosch_InputVoltage changed from NULL to 228.0
2017-09-14 21:27:05.036 [ItemStateChangedEvent ] - UpsRobertBosch_BatteryRuntimeLow changed from NULL to 120.0
2017-09-14 21:27:05.039 [ItemStateChangedEvent ] - UpsRobertBosch_BatteryCharge changed from NULL to 100.0
2017-09-14 21:27:05.041 [ItemStateChangedEvent ] - UpsRobertBosch_Load changed from NULL to 32.0
2017-09-14 21:27:05.043 [ItemStateChangedEvent ] - UPS_APC_RobertBosch_Status changed from NULL to OL
(that was right after reboot…)
So… everything works… but openhab-binding tells nothing works. And that is not nice
Any idea for me??
Thanks,
Patrick
