hi everyone, I am beginner with openhab
i have error when i install openhab2 on raspi 3B
i use raspi 3B and 16G SD card.
I have done like instruction on http://docs.openhab.org/installation/openhabian.html
when i use
openhabianpi-raspbian-20170318-git9767b24-crc9616e8a1.img.
I HAVE EROR
2017-03-03_16:18:59_UTC [openHABian] Booting for the first time! The initial setup might take a few minutes.
2017-03-03_16:19:00_UTC [openHABian] Storing configuration…
2017-03-03_16:19:00_UTC [openHABian] Changing default username and password…
2017-03-03_16:19:01_UTC [openHABian] Setting up Wifi connection… SKIPPED
2017-03-03_16:19:01_UTC [openHABian] Ensuring network connectivity…
2017-03-03_16:19:01_UTC [openHABian] Waiting for dpkg/apt to get ready…
2017-04-08_07:25:22_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2017-04-08_07:28:34_UTC [openHABian] Installing git package… FAILED
2017-03-03_16:18:52_UTC [openHABian] Booting for the first time! The initial setup might take a few minutes.
2017-03-03_16:18:52_UTC [openHABian] Storing configuration…
2017-03-03_16:18:52_UTC [openHABian] Setting up Wifi connection… SKIPPED
2017-03-03_16:18:52_UTC [openHABian] Ensuring network connectivity…
2017-03-03_16:18:52_UTC [openHABian] Waiting for dpkg/apt to get ready…
2017-04-08_07:35:16_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2017-04-08_07:35:55_UTC [openHABian] Installing git package… OK
2017-04-08_07:36:29_UTC [openHABian] Cloning myself… OK
2017-04-08_07:36:33_UTC [openHABian] === Executing ‘openhabian-setup.sh’ ===
2017-04-08_07:36:33_UTC [openHABian] Checking for root privileges… OK
2017-04-08_07:36:33_UTC [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2017-04-08_07:36:33_UTC [openHABian] Setting timezone based on IP geolocation… OK (Asia/Ho_Chi_Minh)
2017-04-08_14:37:49_ICT [openHABian] Setting locale based on openhabian.conf… OK
2017-04-08_14:38:15_ICT [openHABian] Setting hostname of the base system… OK
2017-04-08_14:38:15_ICT [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2017-04-08_14:38:15_ICT [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2017-04-08_14:40:32_ICT [openHABian] Installing additional needed packages… OK
2017-04-08_14:40:51_ICT [openHABian] Adding slightly tuned bash config files to system… OK
2017-04-08_14:40:51_ICT [openHABian] Adding slightly tuned vim config file to system… OK
2017-04-08_14:40:51_ICT [openHABian] Downloading and setting up FireMotD… OK
2017-04-08_14:41:42_ICT [openHABian] Installing etckeeper (git based /etc backup)… OK
2017-04-08_14:42:36_ICT [openHABian] Installing Zulu Embedded OpenJDK… OK
2017-04-08_14:47:03_ICT [openHABian] Installing openHAB 2.0 (stable)… OK
2017-04-08_14:49:36_ICT [openHABian] Adding openHAB syntax to vim editor… OK
2017-04-08_14:49:37_ICT [openHABian] Adding openHAB syntax to nano editor… OK
2017-04-08_14:49:38_ICT [openHABian] Preparing openHAB folder mounts under /srv/… OK
2017-04-08_14:49:38_ICT [openHABian] Applying file permissions recommendations… OK
2017-04-08_14:49:41_ICT [openHABian] Applying miscellaneous system settings… OK
2017-04-08_14:49:41_ICT [openHABian] Setting up Samba for the default user… 2017-03-03_23:18:50_ICT [openHABian] Booting for the first time! The initial setup might take a few minutes.
2017-03-03_23:18:50_ICT [openHABian] Storing configuration…
2017-03-03_23:18:50_ICT [openHABian] Setting up Wifi connection… SKIPPED
2017-03-03_23:18:50_ICT [openHABian] Ensuring network connectivity…
2017-03-03_23:18:50_ICT [openHABian] Waiting for dpkg/apt to get ready…
2017-04-08_14:54:20_ICT [openHABian] Updating repositories and upgrading installed packages… OK
2017-04-08_14:55:01_ICT [openHABian] Installing git package… OK
2017-04-08_14:55:03_ICT [openHABian] Cloning myself… FAILED
2017-03-03_23:18:51_ICT [openHABian] Booting for the first time! The initial setup might take a few minutes.
2017-03-03_23:18:51_ICT [openHABian] Storing configuration…
2017-03-03_23:18:51_ICT [openHABian] Setting up Wifi connection… SKIPPED
2017-03-03_23:18:51_ICT [openHABian] Ensuring network connectivity…
2017-03-03_23:18:51_ICT [openHABian] Waiting for dpkg/apt to get ready…
2017-04-08_15:00:11_ICT [openHABian] Updating repositories and upgrading installed packages… OK
2017-04-08_15:00:48_ICT [openHABian] Installing git package… OK
2017-04-08_15:00:49_ICT [openHABian] Cloning myself… FAILED
I have not installed yet
thanks for help me
