- Platform information:
- Hardware: RasPi 3b 1Gb
- OS: Raspbian GNU/Linux 10 (buster)
- Java Version:
openjdk version “1.8.0_222”
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation) - openHAB version: openHAB 2.5.4-1 (Release Build) - Openhabian
- Issue of the topic: JSR223 Timer Error
I’m on the way to migrate my DSL-Rules to SA, but now I’m struggling with the “createTimer”-Function(lambda)
I have the following items(for testing the channels are unlinked and manually switched):
Switch Sonoff_socket_03 "Steckdose RasPi 3b+ [MAP(de.map):%s]" (gSystem) // (EG_Buro,gPlugSwitch,gSonoff) { channel="mqtt:topic:hans:s2003:power"}
Switch RasPi_online "Office Pi [MAP(tech.map):%s]" (gSystem) // {channel="network:pingdevice:raspi_office:online"}
The Rule is .py:
from core.rules import rule
from core.triggers import when
from core.date import DateTime
#from core.actions import Transformation
from core.actions import ScriptExecution
T_OFFICEPI_STATUS = None
@rule("raspi_online_monitor_office", description="monitors Office Raspi and switch it off after shutdown", tags=["RasPi", "OfficePi"])
@when("Item RasPi_online changed from ON to OFF")
def office_pi_online(event):
office_pi_online.log.info("Rule is running")
if items["Sonoff_socket_03"] == OFF:
office_pi_online.log.info("Steckdose ist bereits ausgeschaltet")
else:
global T_OFFICEPI_STATUS
office_pi_online.log.info("RasPi Office wird in 3 Minuten ausgeschaltet ")
if items["Sonoff_socket_03"] == ON:
if T_OFFICEPI_STATUS is None or T_OFFICEPI_STATUS.hasTerminated():
T_OFFICEPI_STATUS = ScriptExecution.createTimer(DateTime.now().plusMinutes(3), lambda: events.sendCommand(items["Sonoff_socket_03"], "OFF"))
office_pi_online.log.info("Timer runs ")
elif T_OFFICEPI_STATUS is not None and not T_OFFICEPI_STATUS.hasTerminated("TERMINATED"):
T_OFFICEPI_STATUS.cancel()
office_pi_online.log.info("Timer cancelled ")
but when the rule is triggered and the “else”-Condition is true, the following error is logged.
Log:
2020-04-20 14:08:56.224 [INFO ] [3.ohtest.raspi_online_monitor_office] - Rule is running
2020-04-20 14:08:56.237 [INFO ] [3.ohtest.raspi_online_monitor_office] - Steckdose ist bereits ausgeschaltet
2020-04-20 14:09:52.091 [INFO ] [3.ohtest.raspi_online_monitor_office] - Rule is running
2020-04-20 14:09:52.103 [INFO ] [3.ohtest.raspi_online_monitor_office] - RasPi Office wird in 3 Minuten ausgeschaltet
2020-04-20 14:09:52.192 [INFO ] [3.ohtest.raspi_online_monitor_office] - Timer runs
2020-04-20 14:12:52.116 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 1 2020-04-20T14:12:52.109+02:00: <function <lambda> at 0x3> threw an unhandled Exception:
org.python.core.PyException: null
at org.python.core.Py.TypeError(Py.java:259) ~[?:?]
at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:209) ~[?:?]
at org.python.core.PyReflectedFunction.throwBadArgError(PyReflectedFunction.java:312) ~[?:?]
at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:321) ~[?:?]
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:167) ~[?:?]
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204) ~[?:?]
at org.python.core.PyObject.__call__(PyObject.java:496) ~[?:?]
at org.python.core.PyObject.__call__(PyObject.java:500) ~[?:?]
at org.python.core.PyMethod.__call__(PyMethod.java:156) ~[?:?]
at org.python.pycode._pyx43.f$3(<script>:53) ~[?:?]
at org.python.pycode._pyx43.call_function(<script>) ~[?:?]
at org.python.core.PyTableCode.call(PyTableCode.java:167) ~[?:?]
at org.python.core.PyBaseCode.call(PyBaseCode.java:124) ~[?:?]
at org.python.core.PyFunction.__call__(PyFunction.java:403) ~[?:?]
at org.python.core.PyFunction.__call__(PyFunction.java:398) ~[?:?]
at org.python.core.PyFunction.invoke(PyFunction.java:533) ~[?:?]
at com.sun.proxy.$Proxy207.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
2020-04-20 14:12:52.180 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.Timer 1 2020-04-20T14:12:52.109+02:00: <function <lambda> at 0x3> threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: org.python.core.PyException
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
2020-04-20 14:18:51.673 [INFO ] [jsr223.ohtest.Moon distance ] - Moondistance updated every 5 Minutes by "astro.things" 2020-04-20T14:18:51.558+0200 1 / 1 Log every 2 hours
20
If I understand correct, there is something wrong with the “lambda” but I don’t know what and why !!??
I used an example from the Docs
global chargerTimer2
if items["Outlet9"] == ON and event.itemState <= DecimalType(8) and event.oldItemState <= DecimalType(8):
if chargerTimer2 is None or chargerTimer2.hasTerminated():
chargerTimer2 = ScriptExecution.createTimer(DateTime.now().plusMinutes(5), lambda: events.sendCommand("Outlet9","OFF"))
batteryChargingMonitor2.log.info("Battery charging monitor: Started battery charging turn off timer: Outlet9_Power=[{}], oldItemState=[{}]".format(event.itemState, event.oldItemState))
elif chargerTimer2 is not None and not chargerTimer2.hasTerminated():
chargerTimer2.cancel()
batteryChargingMonitor2.log.info("Battery charging monitor: Cancelled battery charging turn off timer: Outlet9_Power=[{}], oldItemState=[{}]".format(event.itemState, event.oldItemState))
but I do not see what’s the difference.
Any help for a fool ?
