- Platform information:
- Hardware: (virtual machine) AMD Opteron 2nd Generation/4 GByte RAM/128 GByte HD
- OS: Xubuntu 22.04 DesktopLTS
- Java Runtime Environment: OpenJAVA 17
- openHAB version: 3.2
- Issue of the topic:
I installed the “Epson Projector Binding” to control my ceiling mounted beamer and created an " Epson Projector"-thing manually. But something went wrong and I want to delete this thing because it always appears into the inbox when opening the inbox and it’s unusable for me due to the error.
But if I select the thing and chose “remove” from the dropdown menu, I always get the error removing entry: Server error".
How can I remove/delete this thing?
Regards
“Klaus”
Did you try to
- use the karaf console to remove the thing ?
- use the API explorer to remove the thing ?
- remove the binding ?
- use Java 11 instead of Java 17 ?
Hi Wolfgang S.,
using the karaf console on the inbox entry seemed to worked ![]()
Thanks for help
