Error when trying to add Shelly BLU Gateway
When trying to add a Shelly BLU Gateway it fails and writes this in the log:
2024-07-14 08:53:13.540 [DEBUG] [shelly.internal.ShellyHandlerFactory] - Shelly BLU Gateway: Create new thing of type shelly:shellyblugw using ShellyBluSensorHandler
2024-07-14 08:53:13.546 [DEBUG] [shelly.internal.ShellyHandlerFactory] - Thing handler for uid shelly:shellyblugw:f36cdb6bb6 added, total things = 1
2024-07-14 08:53:13.548 [DEBUG] [ernal.handler.ShellyBluSensorHandler] - Thing is using class org.openhab.binding.shelly.internal.handler.ShellyBluSensorHandler
2024-07-14 08:53:15.548 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyblugw-f36cdb6bb6: Using default userId admin from binding config
2024-07-14 08:53:15.549 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyblugw-f36cdb6bb6: Using default password from bindingConfig (userId=admin)
2024-07-14 08:53:15.549 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyblugw-f36cdb6bb6: Config: Device address=192.168.19.75, HTTP user/password=admin/***, update interval=60
Events: Button: false, Switch (on/off): true, Push: true, Roller: trueSensor: true, CoIoT: false
Blu Gateway=true, Range Extender: true
2024-07-14 08:53:15.549 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyblugw-f36cdb6bb6: Start initializing for thing Shelly BLU Gateway, type shellyblugw, IP address 192.168.19.75, Gen2: false, CoIoT: false
2024-07-14 08:53:15.793 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyblugw-f36cdb6bb6: Unexpected API result: 404/Not Found
org.openhab.binding.shelly.internal.api.ShellyApiException:
at org.openhab.binding.shelly.internal.api.ShellyHttpClient.innerRequest(ShellyHttpClient.java:213) ~[?:?]
at org.openhab.binding.shelly.internal.api.ShellyHttpClient.httpRequest(ShellyHttpClient.java:113) ~[?:?]
at org.openhab.binding.shelly.internal.api1.Shelly1HttpApi.getDeviceProfile(Shelly1HttpApi.java:132) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.initializeThing(ShellyBaseHandler.java:324) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.lambda$0(ShellyBaseHandler.java:188) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Openhab 4.2
Best Regards, Valter
I too are having the exact same issue trying to add the Shelly BLU Gateway. Has anyone got a workaround or managed to resolve?
Looks like the Binding needs updating. The path to Settings on the BLU Gateway in the URL is now http://BLU-IP/#/settings instead of http://BLU-IP/settings which the Binding is looking for.
This path is invalid causing the 404 Not Found.
same here for a Shelly Plug S Gen 3, see also Adding Shelly BLU Gateway - 404 Not Found from Binding · Issue #18427 · openhab/openhab-addons · GitHub
