Error when upgrading OH 2.4 snapshot
Platform information:
Hardware: RPi 3B+, 120GB SSD, no SD, Aeotec’s Z-stick Gen 5
OS: Opehabian
Java Runtime Environment: -
openHAB version: 2.4.0~20180919034315-1 (Build #1369)
Please post configurations (if applicable):
MAil Action, not yet configured
MapDB Persistence, not yet configured
Z-Wave Binding, 2.4.0.201809182206
At first I must admit that I did not look into “openhab.log” until today (2018-09-21), which I know should
be done after each change in the system and then found the error messages.
After the first installation of OH 2.4 I installed the z-wave controller and a few things, cofigured in
Habmin, and have not noticed any problems.
History:
Installed OH 2.3 image on the SSD and made all available uppdates with openhabian-config:
Upgrade all installed software packages to their newest version. Everything OK.
2018-09-09 Installed OH 2.4 by using openhabian-config: openHAB snapshot Install or switch to
the latest openHAB SNAPSHOT build.
No errors.
2018-09-11 Upgraded OH 2.4 by using: Openhabian-config: Upgrade all installed software packages
The errors now started to show up in the openhab.log.
Error at first upgrade
2018-09-11 14:31:20.483 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot feature repository mvn:org.openhab.distro/distro/2.4.0-SNAPSHOT/xml/features
java.lang.IllegalStateException: BundleContext is no longer valid
	at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:989) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getDataFile(BundleContextImpl.java:694) [?:?]
	at org.apache.karaf.features.internal.osgi.Activator$1.getOutputStream(Activator.java:205) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.StateStorage.save(StateStorage.java:56) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.saveState(FeaturesServiceImpl.java:360) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.addRepository(FeaturesServiceImpl.java:505) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.addRepository(FeaturesServiceImpl.java:491) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.BootFeaturesInstaller.installBootFeatures(BootFeaturesInstaller.java:98) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.BootFeaturesInstaller.start(BootFeaturesInstaller.java:87) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:273) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:242) [10:org.apache.karaf.features.core:4.1.5]
2018-09-11 14:31:20.923 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot feature repository mvn:org.openhab.distro/openhab-addons/2.4.0-SNAPSHOT/xml/features
2018-09-11 14:31:20.971 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot feature repository mvn:org.apache.karaf.features/framework/4.1.5/xml/features
2018-09-11 14:31:21.050 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot feature repository mvn:org.apache.karaf.features/standard/4.1.5/xml/features
2018-09-11 14:31:21.200 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@1bd7a24 rejected from java.util.concurrent.ThreadPoolExecutor@dce4cd[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
	at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063) [?:?]
	at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830) [?:?]
	at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1379) [?:?]
	at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:134) [?:?]
	at java.util.concurrent.Executors$DelegatedExecutorService.submit(Executors.java:681) [?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvisionInThread(FeaturesServiceImpl.java:1146) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installFeatures(FeaturesServiceImpl.java:1022) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installFeatures(FeaturesServiceImpl.java:915) [10:org.apache.karaf.features.core:4.1.5]
	at org.apache.karaf.features.internal.service.BootFeaturesInstaller.installBootFeatures(BootFeaturesInstaller.java:107) [10:org.apache.karaf.features.core:4.1.5]
your code goes here
Error at the last upgrade
2018-09-20 14:14:03.187 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [168:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [168:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [168:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [168:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [167:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [168:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [168:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [165:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [165:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [165:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [165:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [165:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [84:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [84:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [81:org.eclipse.jetty.security:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [183:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [84:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.Server.handle(Server.java:531) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [86:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: org.eclipse.jetty.io.EofException
	at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) ~[74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) ~[74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) ~[74:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:804) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[86:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:538) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:795) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:846) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:240) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:216) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:515) ~[83:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:325) ~[?:?]
	at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[?:?]
	at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:116) ~[?:?]
	at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[?:?]
	at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[?:?]
	at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
	at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
	... 53 more
Caused by: java.io.IOException: Broken pipe
	at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
	at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
	at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
	at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
	at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:266) ~[74:org.eclipse.jetty.io:9.4.11.v20180605]
	... 53 more
What does this mean and can someone help me?
It means snapshots are currently borked, try #1360
I tried for the latest 2.4 yesterday to migrate to the new ZWave binding, and it was a dumpster fire. Random items not existing on startup, some circular reference error, etc. I rolled back to whatever I was running from July and all is well again. Sometimes being on the cutting edge is exactly what it sounds like. :crazy_face:
