i am unable to open penhab cloud getting error
Need more information.
openHAB logs, MongoDB Logs etc.
Just with these few words from you it would be wild guessing.
“Did you check the thing with the stuff so it can work?” (joking here)
hi i resolved that issue by disabling --noauth and after i connected successfully i am getting only login screen in my localhosthttp://localhost:3000/
Is this a new question or a comment?
new question
Did you check this https://docs.openhab.org/addons/ios/openhabcloud/readme.html#uuid-and-secret ?
i am getting login screen where should i keep uuid secret code this is my screenshot link
Should’t this be same as the https://myopenhab.org/login ?
I did not use myopenhab so far.
yes then what should i do
