Error while loading components of bundle org.openhab.io.hueemulation
Hi guys,
For several weeks I have been observing enormous problems with the “org.openhab.io.hueemulation” bundle. First in 2.4 release version Alexa started losing devices. Im now trying to find a working bundle in “testing” as well as “snapshot” builds without any luck.
In the very current snapshot build “openHAB 2.5.0 Build #1701” the bundle is not even starting. Is this a known issue?
Best regards,
Artur
2019-09-28 12:51:46.194 [DEBUG] [org.openhab.io.hueemulation         ] - BundleEvent STARTING - org.openhab.io.hueemulation
2019-09-28 12:51:46.362 [ERROR] [org.apache.felix.scr                ] - bundle org.apache.felix.scr:2.1.16 (43)Error while loading components of bundle org.openhab.io.hueemulation:2.5.0.201909260731 (232)
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Long
	at org.apache.felix.cm.impl.ConfigurationImpl.configure(ConfigurationImpl.java:659) ~[?:?]
	at org.apache.felix.cm.impl.ConfigurationImpl.configureFromPersistence(ConfigurationImpl.java:619) ~[?:?]
	at org.apache.felix.cm.impl.ConfigurationImpl.<init>(ConfigurationImpl.java:194) ~[?:?]
	at org.apache.felix.cm.impl.ConfigurationManager.listConfigurations(ConfigurationManager.java:547) ~[?:?]
	at org.apache.felix.cm.impl.ConfigurationAdminImpl.listConfigurations(ConfigurationAdminImpl.java:190) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.findConfigurations(RegionConfigurationSupport.java:655) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.findSingletonConfiguration(RegionConfigurationSupport.java:554) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configureComponentHolder(RegionConfigurationSupport.java:199) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.setRegionConfigurationSupport(BundleComponentActivator.java:763) ~[?:?]
	at org.apache.felix.scr.impl.helper.ConfigAdminTracker$1.addingService(ConfigAdminTracker.java:69) ~[?:?]
	at org.apache.felix.scr.impl.helper.ConfigAdminTracker$1.addingService(ConfigAdminTracker.java:41) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[?:?]
	at org.apache.felix.scr.impl.helper.ConfigAdminTracker.<init>(ConfigAdminTracker.java:86) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.<init>(BundleComponentActivator.java:275) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:380) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
	at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1153) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1036) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
2019-09-28 12:51:46.997 [DEBUG] [ig.xml.osgi.XmlDocumentBundleTracker] - Reading the XML document '/ESH-INF/config/config.xml' in module 'org.openhab.io.hueemulation'...
2019-09-28 12:51:47.003 [DEBUG] [org.openhab.io.hueemulation         ] - BundleEvent STARTED - org.openhab.io.hueemulation
You should not necessarily expect a snapshot build to work. The testing build 2.5M3 likely does work.
Unfortunately not, same error in 2.5M3 and 2.5 M2. Testing current Snapshot Release (2.5.0~S1705-1) now. I´m just wondering because it seems like the bundle cannot even be started, at least in my environment. So it looks like the hue emulation check-in hasn´t been tested so far? Am I the first one experiencing issues like that?
2019-09-30 12:03:58.483 [DEBUG] [org.openhab.io.hueemulation         ] - BundleEvent STARTING - org.openhab.io.hueemulation
2019-09-30 12:03:58.532 [DEBUG] [org.openhab.io.hueemulation         ] - BundleEvent STARTED - org.openhab.io.hueemulation
2019-09-30 12:03:58.534 [DEBUG] [ig.xml.osgi.XmlDocumentBundleTracker] - Reading the XML document '/ESH-INF/config/config.xml' in module 'org.openhab.io.hueemulation'...
2019-09-30 12:03:58.877 [ERROR] [org.apache.felix.scr                ] - bundle org.apache.felix.scr:2.1.16 (43)Error while loading components of bundle org.openhab.io.hueemulation:2.5.0.201909300426 (235)
any luck figuring this out? I am getting the same error message trying to install hue emulation, using 2.5m1
Unfortunately not, I’m afraid it’s a common problem since other add-ons produce the same error too. (see OpenHab Cloud Binding Crashes on Startup - #5 by Penguin)
I´m on nightly builds now but no fix so far. I don´t think someone is activelly working on it. If I find some time I will setup a development environment and try to debug this.
There is a solution now. Thanks to @Celaeno1 in this post OpenHab Cloud Binding Crashes on Startup - #7 by Celaeno1 and to this topic [SOLVED] No opencloud when upgrading from 2.4 to 2.5M4 - #16 by Celaeno1
I have successfully tested the solution a couple of minutes ago:
In the folowing folder /var/lib/openhab2/config/org/openhab/ there is a config file hueemulation.config
In my case the first line in this config file was:
:org.apache.felix.configadmin.revision:=“8.0”
I changed it to:
:org.apache.felix.configadmin.revision:=L"8"
Thanks a lot to @Celaeno1
