Error while upgrade via openhabian-config from 4.2.0
a few month ago I did an update-orgy from debian buster over bullseye to bookworm and OH 4.2.0.
Everything went fine so far and was running.
I got some trouble with the keyrings after the upgrade to bookworm but corrected this so “apt-get update” has no errors.
This weekend I wanted to upgrade to OH 4.2.2. So I logged in, ran “openhabian-config” and selected “02 Upgrade System”. But it aborts with an error or interruption during execution of “02 Upgrade System”.
While downloading the packages I get the following error:
+Fehl:8 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab-addons all 4.2.2-1 400 Bad Request [IP: 2a00:1450:4005:801::201b 443]
But only at this package, all other packages got no errors
/etc/apt/sources.list.d/openhab.list looks like following:
deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main
The machine is behind a PiHole DNS but even if I disable blocking I get this error.
  • Platform information:
    • Hardware: RPi3B+/1GB
    • OS: openhabian bookworm
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version: 4.2.0
      Can anyone help me please?
It looks like a temporary problem with the JFrog server that hosts the OH installation files. Is this still a problem?
Sorry, was not at home this week.
Yes, the problem still exists. :frowning:
//Edit 12/03:
The problem is still the same…
Can no one help please? :frowning:
//Edit 12/30:
I tried the Upgrade via normal apt and got the error 2 or 3 times again but finally it worked. So OH 4.3 is up and running now. :slight_smile:
