Error with DecimalType
I have a problem with this rule…
In the log the following error comes up and I can´t solve it, hope someone can help :blush:
Rule 'Set alarm timers': org.eclipse.smarthome.core.library.types.DecimalType
import org.eclipse.smarthome.core.library.types.DecimalType
import org.eclipse.smarthome.model.script.actions.Timer
import org.joda.time.DateTime
var Timer thermostatTimer = null
var Timer testTimer = null
rule "Set alarm timers"
Item heiz_wecker_joerg_timer received command
var int zeit = (heiz_wecker_joerg_timer.state as DecimalType).intValue
val alarmDT = new DateTime(now.plusSeconds(60))
heiz_wecker_joerg.sendCommand(alarmDT.toString)
  if(testTimer != null) testTimer.cancel
  testTimer = createTimer(now.plusSeconds(zeit), [ |
      heiz_handtuch_bad.sendCommand(ON)
      testTimer = null
Items:
String heiz_wecker_joerg “Wecker Heizung Jörg [%s]”
String heiz_wecker_joerg_timer “Timer Heizung Jörg [%s]”
What is the error message?
Silly me… see first line… duh…
It is already above :wink:
heiz_wecker_joerg_timer is defined as a string, not a number
Typical parsing example here
