I encounter the following issue when following these instructions to configure zigbee2mqtt in a lxd container.
I did apt update & upgrade, but it does not help. Note that in lxd containers, there is only root.
root@OpenHAB:/opt/zigbee2mqtt# node --version
v10.19.0
root@OpenHAB:/opt/zigbee2mqtt# npm --version
6.14.4
root@OpenHAB:/opt/zigbee2mqtt# node-pre-gyp info ok
node-pre-gyp info it worked if it ends with ok
node-pre-gyp info using node-pre-gyp@0.10.2
node-pre-gyp info using node@10.19.0 | linux | x64
node-pre-gyp ERR! UNCAUGHT EXCEPTION
node-pre-gyp ERR! stack Error: Cannot find module 'aws-sdk'
node-pre-gyp ERR! stack at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
node-pre-gyp ERR! stack at Function.Module._load (internal/modules/cjs/loader.js:562:25)
node-pre-gyp ERR! stack at Module.require (internal/modules/cjs/loader.js:692:17)
node-pre-gyp ERR! stack at require (internal/modules/cjs/helpers.js:25:18)
node-pre-gyp ERR! stack at unpublish (/usr/lib/nodejs/node-pre-gyp/lib/info.js:14:15)
node-pre-gyp ERR! stack at Object.self.commands.(anonymous function) [as info] (/usr/lib/nodejs/node-pre-gyp/lib/node-pre-gyp.js:52:37)
node-pre-gyp ERR! stack at run (/usr/lib/nodejs/node-pre-gyp/bin/node-pre-gyp:82:30)
node-pre-gyp ERR! stack at Object.<anonymous> (/usr/lib/nodejs/node-pre-gyp/bin/node-pre-gyp:134:1)
node-pre-gyp ERR! stack at Module._compile (internal/modules/cjs/loader.js:778:30)
node-pre-gyp ERR! stack at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
node-pre-gyp ERR! System Linux 5.8.0-53-generic
node-pre-gyp ERR! command "/usr/bin/node" "/usr/bin/node-pre-gyp" "info" "ok"
node-pre-gyp ERR! cwd /opt/zigbee2mqtt
node-pre-gyp ERR! node -v v10.19.0
node-pre-gyp ERR! node-pre-gyp -v v0.10.2
node-pre-gyp ERR! This is a bug in `node-pre-gyp`.
node-pre-gyp ERR! Try to update node-pre-gyp and file an issue if it does not help:
node-pre-gyp ERR! <https://github.com/mapbox/node-pre-gyp/issues>
I manually installed aws-sdk, its in the folder node_modules, but this still does not help
root@OpenHAB:/opt/zigbee2mqtt# ls node_modules/
@babel esprima jest-resolve rimraf
@bcoe esquery jest-resolve-dependencies rsvp
@cnakazawa esrecurse jest-runner run-parallel
@dabh estraverse jest-runtime safe-buffer
@eslint esutils jest-serializer safe-regex
@istanbuljs etag jest-snapshot safer-buffer
@jest event-emitter jest-util sane
@nodelib events jest-validate sax
@sinonjs exec-sh jest-watcher saxes
@types execa jest-worker semver
@typescript-eslint exit jmespath send
abab expand-brackets js-tokens serve-static
acorn expect js-yaml set-blocking
acorn-globals ext jsbn set-value
acorn-jsx extend jsdom setprototypeof
acorn-walk extend-shallow jsesc shebang-command
ajv extglob json-parse-even-better-errors shebang-regex
ansi-colors extsprintf json-schema shellwords
ansi-escapes fast-deep-equal json-schema-traverse signal-exit
ansi-regex fast-glob json-stable-stringify-without-jsonify simple-swizzle
ansi-styles fast-json-stable-stringify json-stringify-safe sisteransi
anymatch fast-levenshtein json5 slash
argparse fast-safe-stringify jsprim slice-ansi
arr-diff fastq kind-of snapdragon
arr-flatten fb-watchman kleur snapdragon-node
arr-union fecha kuler snapdragon-util
array-union file-entry-cache leven source-map
array-unique file-uri-to-path levn source-map-resolve
asn1 fill-range lines-and-columns source-map-support
assert-plus finalhandler locate-path source-map-url
assign-symbols find-up lodash spdx-correct
astral-regex flat-cache lodash.sortby spdx-exceptions
async flatted logform spdx-expression-parse
asynckit fn.name lru-cache spdx-license-ids
atob for-in make-dir split-string
aws-sdk forever-agent makeerror split2
aws-sign2 form-data map-cache sprintf-js
aws4 fragment-cache map-visit sshpk
babel-jest fresh merge-stream stack-trace
babel-plugin-istanbul fs.realpath merge2 stack-utils
babel-plugin-jest-hoist fsevents micromatch static-extend
babel-preset-current-node-syntax function-bind mime statuses
babel-preset-jest functional-red-black-tree mime-db stealthy-require
balanced-match gensync mime-types stream-shift
base get-caller-file mimic-fn string-length
base64-js get-package-type minimatch string-width
bcrypt-pbkdf get-stream minimist string_decoder
bindings get-value mixin-deep strip-ansi
bl getpass mkdir-recursive strip-bom
brace-expansion git-last-commit moment strip-eof
braces glob mqtt strip-final-newline
browser-process-hrtime glob-parent mqtt-packet strip-json-comments
bser glob-stream ms supports-color
buffer globals nan supports-hyperlinks
buffer-from globby nanomatch symbol-tree
cache-base glossy natural-compare table
callback-stream graceful-fs next-tick terminal-link
callsites growly nice-try test-exclude
camelcase har-schema node-int64 text-hex
capture-exit har-validator node-modules-regexp text-table
caseless has node-notifier throat
chalk has-flag normalize-package-data through2
char-regex has-value normalize-path through2-filter
ci-info has-values npm-run-path tmp
cjs-module-lexer help-me nwsapi tmpl
class-utils hosted-git-info oauth-sign to-absolute-glob
cliui html-encoding-sniffer object-assign-deep to-fast-properties
co html-escaper object-copy to-object-path
collect-v8-coverage http-errors object-visit to-regex
collection-visit http-signature object.pick to-regex-range
color human-signals on-finished toidentifier
color-convert humanize-duration once tough-cookie
color-name iconv-lite one-time tr46
color-string ieee754 onetime triple-beam
colors ignore optionator tslib
colorspace import-fresh ordered-read-streams tsutils
combined-stream import-local p-each-series tunnel-agent
commist imurmurhash p-finally tweetnacl
component-emitter inflight p-limit type
concat-map inherits p-locate type-check
concat-stream ip-regex p-try type-detect
convert-source-map is-absolute parent-module type-fest
copy-descriptor is-accessor-descriptor parse-json typedarray
core-util-is is-arrayish parse5 typedarray-to-buffer
cross-spawn is-buffer parseurl unc-path-regex
cssom is-ci pascalcase union-value
cssstyle is-core-module path-dirname unique-stream
d is-data-descriptor path-exists unix-dgram
dashdash is-descriptor path-is-absolute unpipe
data-urls is-docker path-key unset-value
debounce is-extendable path-parse uri-js
debug is-extglob path-type urix
decamelize is-fullwidth-code-point performance-now url
decimal.js is-generator-fn picomatch use
decode-uri-component is-glob pirates util-deprecate
deep-is is-negated-glob pkg-dir uuid
deepmerge is-number posix-character-classes v8-compile-cache
define-property is-plain-object prelude-ls v8-to-istanbul
delayed-stream is-potential-custom-element-name pretty-format validate-npm-package-license
depd is-relative process-nextick-args verror
destroy is-stream progress w3c-hr-time
detect-newline is-typedarray prompts w3c-xmlserializer
diff-sequences is-unc-path psl walker
dir-glob is-windows pump webidl-conversions
doctrine is-wsl pumpify whatwg-encoding
domexception isarray punycode whatwg-mimetype
duplexify isexe qs whatwg-url
ecc-jsbn isobject querystring which
ee-first isstream range-parser which-module
emittery istanbul-lib-coverage react-is winston
emoji-regex istanbul-lib-instrument read-pkg winston-syslog
enabled istanbul-lib-report read-pkg-up winston-transport
encodeurl istanbul-lib-source-maps readable-stream word-wrap
end-of-stream istanbul-reports regex-not wrap-ansi
enquirer jest regexpp wrappy
error-ex jest-changed-files reinterval write-file-atomic
es5-ext jest-config remove-trailing-separator ws
es6-iterator jest-diff repeat-element xml-name-validator
es6-map jest-docblock repeat-string xml2js
es6-set jest-each request xmlbuilder
es6-symbol jest-environment-jsdom request-promise-core xmlchars
escape-html jest-environment-node request-promise-native xtend
escape-string-regexp jest-get-type require-directory y18n
escodegen jest-haste-map require-from-string yallist
eslint jest-jasmine2 require-main-filename yargs
eslint-config-google jest-leak-detector resolve yargs-parser
eslint-plugin-jest jest-matcher-utils resolve-cwd zigbee-herdsman
eslint-scope jest-message-util resolve-from zigbee-herdsman-converters
eslint-utils jest-mock resolve-url zigbee2mqtt-frontend
eslint-visitor-keys jest-pnp-resolver ret
espree jest-regex-util reusify
