Errors after start of OH service (org.openhab.core.semantics.internal.SemanticsMetadataProvider)
Hi everyone,
before I switch to OH 4.0, I would like to clear all the errors in the log. After starting the OH service (and only after starting), I see several errors similar to the ones below. I have already checked that I do not have items in more than one semantically tagged groups, which was the case, but even after deleting the tags, the errors remain the same.
Can you please advise how to find the root cause of these errors?
  • Platform information:
    • Hardware: Raspberry Pi 4
    • OS: openHABian (bullseye)
    • Java Runtime Environment: 11
    • openHAB version: 3.4.5
2023-08-27 20:23:42.124 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.semantics.internal.SemanticsMetadataProvider@17ea607" about the "ADDED" event: null
	at java.util.TreeMap.getEntry(TreeMap.java:345) ~[?:?]
	at java.util.TreeMap.get(TreeMap.java:277) ~[?:?]
	at org.openhab.core.semantics.SemanticTags.getById(SemanticTags.java:65) ~[?:?]
	at org.openhab.core.semantics.SemanticTags.getSemanticType(SemanticTags.java:115) ~[?:?]
	at org.openhab.core.semantics.internal.SemanticsMetadataProvider.processItem(SemanticsMetadataProvider.java:110) ~[?:?]
	at org.openhab.core.semantics.internal.SemanticsMetadataProvider.processItem(SemanticsMetadataProvider.java:130) ~[?:?]
	at org.openhab.core.semantics.internal.SemanticsMetadataProvider.added(SemanticsMetadataProvider.java:252) ~[?:?]
	at org.openhab.core.semantics.internal.SemanticsMetadataProvider.added(SemanticsMetadataProvider.java:1) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:367) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.notifyListenersAboutAddedElement(AbstractRegistry.java:400) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.notifyListenersAboutAddedElement(ItemRegistryImpl.java:379) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.notifyListenersAboutAddedElement(ItemRegistryImpl.java:1) ~[?:?]
	at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:432) ~[?:?]
	at org.openhab.core.internal.items.ItemRegistryImpl.addProvider(ItemRegistryImpl.java:410) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:149) ~[?:?]
	at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:943) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:871) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:903) ~[osgi.core-7.0.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:956) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:495) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1271) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1222) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-7.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) ~[osgi.core-7.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:944) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:486) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:464) ~[org.eclipse.osgi-3.17.200.jar:?]
	at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1160) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1041) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
