Errors after upgrade from openhab 4.x to 5.x
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: what OS is used and which version
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version:
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
  • Setting up openhab (5.0.0-1) …
    /var/lib/dpkg/info/openhab.postinst: 34: /etc/default/openhab: -Duser.timezone=Europe/Berlin: not found
    dpkg: error processing package openhab (–configure):
    installed openhab package post-installation script subprocess returned error exit status 127
    dpkg: dependency problems prevent configuration of openhab-addons:
    openhab-addons depends on openhab; however:
    Package openhab is not configured yet.
dpkg: error processing package openhab-addons (–configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
openhab
openhab-addons
Updating FireMotD available updates count …
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
2025-08-05_16:15:55_CEST [openHABian] Checking for default openHABian username:password combination… FAILED
2025-08-05_16:15:56_CEST [openHABian] We hope you got what you came for! See you again soon :wink:
what can i do to resolve this trouble?
thanks for help
cg
Are you running on a 32-bit OS? As mentioned in the [release notes]( criptEngine for language ‘application/vnd.openhab.dsl.rule’ could not be found )
openHABian will refuse to install or upgrade to openHAB 5 when it detects a 32 bit operating system.
Further details can be found at the link.
If you are on 64-bit OS an the upgrade fails, please post the full logs. And please use code fences.
code and logs go here
Openhabian is installed and the os is 64 bit!
uname -m → aarch64
dpkg --print-architecture → arm64
the file os-release
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https://www.debian.org/
SUPPORT_URL=“Debian -- User Support
BUG_REPORT_URL=“https://bugs.debian.org/
For installation i had use the openhab image!
Thanks for help!
I don’t know if openhabian-config automatically installs Java 21 or if you have to do that as a separate step. That’s the next thing to try. Install Java 21 through openhabian-config and then try to upgrade openHAB.
You need to fix that line in that file, probably the quotation marks are in the wrong place
the line in /etc/default/openhab is the following:
EXTRA_JAVA_OPTS=“-Xms192m -Xmx768m -XX:-TieredCompilation -XX:TieredStopAtLevel=1 -XX:+ExitOnOutOfMemoryError -Dxtext.qn.interning=true” -Duser.timezone=Europe/Berlin
What must i change?
The closing " needs ton go at the end of the line.
The big question is what added that and why did it do so incorrectly? Is this a file you’ve changed?
Note, please post code, configs, and logs using code fences so he autoformatting applied by the forum and white space is preserved.
code goes here
this is the original line i had found, i had no make changes manually!
OK, no anderstand, i will remove the " and move it at the end from this line
