ESP32 board - OTA upgrade fail
Hi - i’m working with a kincony KC868-A8 v1.7 board and i would like to install ESP32.
I think the board itself is ok as i can install the KCS firmware from the vendor and also a basic ESP32 yaml ( About | KC868-A8 Smart Controller ).
This one is the unique yaml i uploaded and got it work.
Problem is: whatever i try to load via OTA upgrade, it fails and ignore my loaded config.
KC868 console shows me this:
[D][web_server_base:073]: OTA in progress: 38.0%
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x4000c2e0  PS      : 0x00060a30  A0      : 0x800885ee  A1      : 0x3ffd2120
A2      : 0x3ffd2140  A3      : 0x00000000  A4      : 0x00000010  A5      : 0x3ffd2140
A6      : 0x00060021  A7      : 0x00000001  A8      : 0x00000000  A9      : 0x001d0000
A10     : 0x3ffbdaac  A11     : 0x00060023  A12     : 0x00060021  A13     : 0x00000a9d
A14     : 0x0000002a  A15     : 0x3ffd2220  SAR     : 0x0000000b  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0x00000000
ELF file SHA256: 0000000000000000
Backtrace: 0x4000c2e0:0x3ffd2120 0x400885eb:0x3ffd2130 0x4015749d:0x3ffd2180 0x400e66e6:0x3ffd21a0 0x400df9a6:0x3ffd21c0 0x400dfb4a:0x3ffd21e0        0x400dfd89:0x3ffd2200 0x400db58a:0x3ffd2240 0x400e1ca5:0x3ffd2290 0x400e2e2e:0x3ffd2300 0x400e2fed:0x3ffd2350 0x4015b221:0x3ffd2370 0x4015b29        d:0x3ffd23b0 0x4015b94a:0x3ffd23d0 0x4008a4fa:0x3ffd2400
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
Any idea? Thank you
I don’t know why the OTA upgrade was not working - but flashing it using esphome via powershell fixed the issue.
