ESPHome Audio Streaming on ESP32-S3 – Any OpenHAB Integration Ideas?
Hi everyone,
I’ve been exploring the ESP32-S3 for offline voice control, and I wanted to share some info and see if anyone has insights or is already working on it.
Background
  • The ESP32-S3 chip has been around since 2021 and comes with AI/DSP acceleration, which makes it ideal for audio tasks like microphone input, keyword spotting, and simple speech processing.
  • ESPHome added experimental audio pipeline support starting mid-2023, and by ESPHome 2023.8 the voice_assistant: component was introduced.
What voice_assistant: Does
  • Streams microphone input in real time from ESP32-S3 devices.
  • Uses ESPHome’s native API (protobuf) for efficient, low-latency audio streaming.
  • Currently designed only for Home Assistant, where the audio can be sent to any STT engine (Whisper, Piper, Google STT, etc.).
Limitation for OpenHAB
  • OpenHAB has no native support for ESPHome audio streaming.
  • That means the efficient streaming path from the ESP32-S3 is not accessible natively.
  • Workarounds today would require:
    1. Sending audio via HTTP uploads (WAV/RAW clips) or MQTT (Base64), which is less efficient.
    2. Implementing a bridge/gateway that understands the ESPHome audio protocol and forwards audio to OpenHAB/STT.
    3. Developing a dedicated OpenHAB binding to support ESPHome’s protobuf audio stream.
Why This Is Exciting
  • ESP32-S3 + I²S microphone = a low-cost, distributed, offline voice control solution.
  • With wake-word detection running locally (e.g., microWakeWord), the device can wake up locally and stream audio only when needed.
  • OpenHAB could greatly benefit from the same efficiency and low-latency pipeline if someone implements support.
So my question to the community:
  • Has anyone started working on an OpenHAB binding or middleware for ESPHome audio?
  • Any ideas for a lightweight approach to integrate the ESP32-S3 voice_assistant: pipeline into OpenHAB?
Would love to hear thoughts, tips, or if someone has already experimented with this.
Thanks!
PS: Read this Creation an voice audio satellite with the help of an Esp32 - #11 by moe
But did not see any result…
PPS: Waveshare ESP32-S3 1.46 Inch Round Display Development Board, 412 x 412, Supports Wi-Fi & BLT, Accelerometer and Gyroscope Sensor, Onboard Speaker and Microphone, with Protective Cover Glass: Amazon.de: Computer & Accessories
Hardware is getting realy cheap (on Ali even 50% of that)
I think there is an ESPHome add-on on the marketplace.It seems like adding audio support to that would be easier than creating a whole new add-on.
But in general, an add-on is probably the “correct” approach.
I think Willow - Open Source Echo/Google Home Quality Speech Hardware for $50 is based on the ESP32-S3 too so there might be something you can take from there as an alternative to ESPHome or in addition to ESPHome.
That was my intention :folded_hands:
Not jumped into code, but ESPHome is prepared for customExtensions. So I hope we stay with that “Jack of all trades” :sweat_smile:
