ESPhome dashboard - instalation Problems
Hi Guys,
today, I’m here with a Problem during the installation of the optional ESSPhome component of Openhabian.
I have already made an ticket on github which was closed because I use Ubuntu as my base OS, which is absolutly correct from the maintainers.
https://github.com/openhab/openhabian/issues/1994
Afterward I tried the same with an fresh Debian 12 installation and also with an official RPi image, and I was running into the same issue.
So my question is if anyone had the same Problems with the installation.
@milo I believe this is your code which is inside the openhabian config for that.
If anyone could help I would be very happy and if anyone needs more information please tell what you need.
PS: all packages are up to date :wink:
Mhhm strange…
Can you check
cd /opt/esphomedashboard
ls venv
You ran it as root? If not it might be a user access issue
yes, the openhabia-config is running as sudo.
I don’t know, but in my opinion the file which the script is looking for is available on all 3 system.
Ubuntu:
openhabian@openhab:/opt/esphomedashboard$ ls venv
bin  include  lib  lib64  pyvenv.cfg
openhabian@openhab:/opt/esphomedashboard/venv/bin$ ls
Activate.ps1                        aioesphomeapi-discover  async-json-rpc-server  espefuse.py   hex2bin.py     menuconfig    pip                python                                        savedefconfig
__pycache__                         aioesphomeapi-logs      bin2hex.py             esphome       hex2dump.py    normalizer    pip3               python-argcomplete-check-easy-install-script  setconfig
activate                            alldefconfig            bottle                 espsecure.py  hexdiff.py     oldconfig     pip3.10            python3                                       tabulate
activate-global-python-argcomplete  allmodconfig            bottle.py              esptool.py    hexinfo.py     olddefconfig  platformio         python3.10                                    uvicorn
activate.csh                        allnoconfig             defconfig              genconfig     hexmerge.py    pio           pyserial-miniterm  readelf.py
activate.fish                       allyesconfig            esp_rfc2217_server.py  guiconfig     listnewconfig  piodebuggdb   pyserial-ports     register-python-argcomplete
activate
# This file must be used with "source bin/activate" *from bash*
# you cannot run it directly
deactivate () {
    # reset old environment variables
    if [ -n "${_OLD_VIRTUAL_PATH:-}" ] ; then
        PATH="${_OLD_VIRTUAL_PATH:-}"
        export PATH
        unset _OLD_VIRTUAL_PATH
    fi
    if [ -n "${_OLD_VIRTUAL_PYTHONHOME:-}" ] ; then
        PYTHONHOME="${_OLD_VIRTUAL_PYTHONHOME:-}"
        export PYTHONHOME
        unset _OLD_VIRTUAL_PYTHONHOME
    fi
    # This should detect bash and zsh, which have a hash command that must
    # be called to get it to forget past commands.  Without forgetting
    # past commands the $PATH changes we made may not be respected
    if [ -n "${BASH:-}" -o -n "${ZSH_VERSION:-}" ] ; then
        hash -r 2> /dev/null
    fi
    if [ -n "${_OLD_VIRTUAL_PS1:-}" ] ; then
        PS1="${_OLD_VIRTUAL_PS1:-}"
        export PS1
        unset _OLD_VIRTUAL_PS1
    fi
    unset VIRTUAL_ENV
    unset VIRTUAL_ENV_PROMPT
    if [ ! "${1:-}" = "nondestructive" ] ; then
    # Self destruct!
        unset -f deactivate
    fi
# unset irrelevant variables
deactivate nondestructive
VIRTUAL_ENV=/opt/esphomedashboard/venv
export VIRTUAL_ENV
_OLD_VIRTUAL_PATH="$PATH"
PATH="$VIRTUAL_ENV/"bin":$PATH"
export PATH
# unset PYTHONHOME if set
# this will fail if PYTHONHOME is set to the empty string (which is bad anyway)
# could use `if (set -u; : $PYTHONHOME) ;` in bash
if [ -n "${PYTHONHOME:-}" ] ; then
    _OLD_VIRTUAL_PYTHONHOME="${PYTHONHOME:-}"
    unset PYTHONHOME
fi
if [ -z "${VIRTUAL_ENV_DISABLE_PROMPT:-}" ] ; then
    _OLD_VIRTUAL_PS1="${PS1:-}"
    PS1='(venv) '"${PS1:-}"
    export PS1
    VIRTUAL_ENV_PROMPT='(venv) '
    export VIRTUAL_ENV_PROMPT
fi
fi
Debian 12:
patrick@openhabian:/opt/esphomedashboard$ ls venv
patrick@openhabian:/opt/esphomedashboard$ ls venv/bin
activate                            alldefconfig           bottle.py              esptool.py   hexmerge.py    piodebuggdb        pyserial-ports                                savedefconfig
activate.csh                        allmodconfig           cairosvg               genconfig    listnewconfig  pip                python                                        setconfig
activate.fish                       allnoconfig            defconfig              guiconfig    menuconfig     pip3               python3                                       tabulate
activate-global-python-argcomplete  allyesconfig           espefuse.py            hex2bin.py   normalizer     pip3.11            python3.11                                    uvicorn
Activate.ps1                        async-json-rpc-server  esphome                hex2dump.py  oldconfig      platformio         python-argcomplete-check-easy-install-script
aioesphomeapi-discover              bin2hex.py             esp_rfc2217_server.py  hexdiff.py   olddefconfig   __pycache__        readelf.py
aioesphomeapi-logs                  bottle                 espsecure.py           hexinfo.py   pio            pyserial-miniterm  register-python-argcomplete
activate
deactivate () {
        export PATH
    fi
        export PYTHONHOME
    fi
    fi
        export PS1
    fi
    unset VIRTUAL_ENV
    # Self destruct!
        unset -f deactivate
    fi
export VIRTUAL_ENV
export PATH
    unset PYTHONHOME
fi
    export PS1
fi
fi
RPI 4 official Openhabian image:
openhabian@openhabian:/opt/esphomedashboard $ cd /opt/esphomedashboard
openhabian@openhabian:/opt/esphomedashboard $ ls venv
openhabian@openhabian:/opt/esphomedashboard $ ls venv/bin
activate  activate.csh  activate.fish  Activate.ps1  pip  pip3  pip3.11  python  python3  python3.11
activate
deactivate () {
        export PATH
    fi
        export PYTHONHOME
    fi
    fi
        export PS1
    fi
    unset VIRTUAL_ENV
    # Self destruct!
        unset -f deactivate
    fi
export VIRTUAL_ENV
export PATH
    unset PYTHONHOME
fi
    export PS1
fi
fi
@milo I believe i had an idea:
original Code from Github:
    echo "$(timestamp) [openHABian] Activating the virtual environment and installing ESPHome..."
    if ! sudo -u "$USER" bash -c "source venv/bin/activate && pip install esphome"; then
      echo "$(timestamp) [openHABian] Error: Failed to install ESPHome."
      return
    fi
I beliieve the command should be
sudo -u "$USER" bash -c "source $ESPHOME_DIR/venv/bin/activate && pip install esphome";
instead of
@milo are you able to have a look about it?
@all does anyone else get the same problem with the following Versions?
openHABian Configuration Tool — [openHAB]{2025-04-27T00:37:57-06:00}(7f01c79)
openHAB 4.3.5 - Release Build
@Oetzi-1987 Sorry I have right now some troubles with my raspberry pi and I need to have a look at this first… But anyway I guess you are right wth the path but as I tested before it runs fine…I am now on dietpi therefore no need of openhabian anymore
Hi.
I have not been able to install the espHome dasboard (didn’t know it was was available till i saw the first post for this thread several days ago). I updated my OH system earlier today and am encountering the same error for the file/directory not found.
My system is set up as a proxmox VM with Debian 12 x86.
The error is receive after running the installation with openHABian-config:
2025-06-01_08:06:17_EDT [openHABian] Activating the virtual environment and installing ESPHome...
bash: line 1: venv/bin/activate: No such file or directory
Craig
wohoo I’m not the only one :smiley:
@milo don’t stress up i’m not in a hury :wink:
if you need any informations from my side or if i should open a ticket @github give me a hint and i will be here.
I am not sure if I can fix it so fast …as I wrote I am on dietpi now and have right now no big interest to setup an pi with openhabian during summer time
@milo thats not a big deal i know your situation my garden and my wife also need more attention in summer than in winter :wink:
@mstormi maybe you could reopen the Github ticket and link to this post, so no one forgets this open issue :wink:
Hi Guys,
I made some major improvemts of the script from @milo I had some questions:
  1. what would be the best path for the configurationfolder, so that the openhabian Backup function is catching this files
  2. How can i get the permission to create a new branch to upload the files on Github?
  1. I am not the openhabian maintainer, can’t answer these questions ( I also asked these questions but there was no answer for me) but @mstormi can answer?
  2. Simply create a GitHub pull request
That’s a misunderstanding. There’s no openHABian backup function, only - optional - full system backups via Amanda or the SD mirror.
So that’s not really a factor in choosing the install dir.
There’s /opt/openhabian/includes and its subdirs for scripts.
@mstormi I’m not talking about the install path. I would like to aks for a good path where the configuration files for all the ESPhome devices getting saved when I would use the openhabian option “50 | Backup/Restore”
That is not the way to go. That option calls the openhab-cli script from the openhab(not -ian) distro which will only ever backup a fixed set of files that belong to openhab not any 3rd party tool like ESPhome is.
As I said there is no openHABian backup tool that would or could take care of your stuff.
Sorry Guys, for the long time which i need since my last reply :frowning:
Since this morning, a fixed install / update and remove script is available for the ESPHome Device builder inside openhabian! :slight_smile:
Please test it on your system and if there are any issues pleas give me a call.
Please also take a look at the Doc section about the Update, which is necessary if newer ESPHome Versions are available.
@mstormi thank you for your support and patience during my first pull request on git
Hi Guys during the bracking changes in ESPHome (splitting the Device Builder and the CLI Application) I have to update my script in Openhabian.
In that case the correect way is tu uninstall the old version including the service and the venv where it it installed.
Would it be enough to write a hint in the Setup, and also for headless guys, in the Documentation,
that if you want to make this major update, you have to use first the uninstall and then the install script or has inside the script a logic which is detecting that?
Otherwise the update won’t work, because of changes in the service.
I’m struggling at this point because of this is a bigger function which is used just for a short time until everyone is up to the new major version.
@mstormi you are one of the maintainers what dou you and the rest of the community think about?
I had the same situation with my zigbee2mqtt install-function. I finally decided not to support the major update but leave this to the user. The reason was that there might be a large amount of different cases (OS versions, node …) I would have to consider… and cannot test… and that’s no fun… and the code gets awful.
I think it was the right decision: Only a handful of users needed support (e.g. not matching node.js versions) but the majority managed by themselves or got help from other experienced users.
So I think an info box would be totally fine.
@Larsen thank you for the feedback i made a whiptail message an also a hint in the Documentation for that :slight_smile:
