I donāt understand what you mean by additional devices?
What i saw in the log above was no communications with the stick. The binding then throws an exception as it didnāt get the IEEE address from the stick.
This doesnāt happen when thereās only one coordinator Thing, but start happening as soon as a second coordinator is added.
This happens even with a single coordinator, after disabling/re-enabling it.
The log format is the standard one, I havenāt changed it (or not intentionally, at least)
So here you are disabling and re-enabling the same coordinator? . Seems a little strange - the response from the device sometimes is ok, and other times looks invalid. Iāll try and decode the responses manuallyā¦
Firstly, the incorrect response is received - we receive 00 instead of 53. Packet 00 which is a version response rather than the config request that was sent. Second, this is an incorrect version request as itās too short, and this is probably what is causing the error.
This seems to be caused by invalid response from the stick from what I can tell.
I assume youāre using the standard Xmodem bootloader? If so, it would be great if you could release the file zipped with the metadata so that it can be booted directly in openHAB?
Yes, Xmodem bootloader.
Sounds great. We will look into it and prepare the zipped metadata.
Glad to hear.
Yes. indeed the ELU013 devices are internally marked as ELR023.
They share the same firmware. We mainly use this field to distinguish them from previous generation ELR022, ELU012, which were based on EFR32MG1 and require a different firmware.
quick report: new network, 28 devices paired (2 CC2531 routers, 1 IKEA bulb, Aqara sensors, no OSRAM bulbs).
The network is stable, no delays, and only a few packets go around once the discovery is finished.
The only issues so far:
failure to start the network after the first time (restarting OH is necessary)
error in setting the stick configuration during startup (EZSP_ERROR_INVALID_ID and EZSP_ERROR_OUT_OF_MEMORY, both visible in the log at https://pastebin.com/RaG2Gwaq)
I will finish pairing all the end devices I have around, then let it run for a few days. I want then to re-add my OSRAM bulbs and see if maybe they are the cause of all my headachesā¦
@chris Did you get the information from @Elelabs to build the firmware? It may help me (and others Iām sure) to figure out what Zigbee dongle to choose when considering this protocol ecosystem.
No - unfortunately I didnāt receive a response. I know others are having problems with this under windows so understanding what is inside would help us support and know what drivers are required.
