Eurotronic Spirit - Unsupported mode type 31
Thank you guys for your help :slight_smile:
I just missed “magic command” to be executed in console. This thread is so long and I wanted to read it all before posting.
After your suggestions I have managed to solve the problem.
Thank you again!
Winter came and the Spirit started to live with its own life again - my wife is telling mi to get rid of those :face_with_symbols_over_mouth:. I moved to OH3 but it seems that mode 31 is still disabled.
I’m trying to test it using simple rules - I send the command to switch to manual mode but it responds with error about unsupported mode.
Is there a “proper” way of switching it to manual control? Basic channel is not available in OH3.
2021-01-23 18:17:52.027 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'GabinetGrzejnikNode10_Thermostatmode' received command 31
2021-01-23 18:17:52.055 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'GabinetGrzejnikNode10_Thermostatmode' predicted to become 31
2021-01-23 18:17:52.075 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'GabinetGrzejnikNode10_Thermostatmode' changed from 1 to 31
2021-01-23 18:17:52.080 [ERROR] [lass.ZWaveThermostatModeCommandClass] - NODE 10: Unsupported mode type 31
2021-01-23 18:17:52.084 [WARN ] [nverter.ZWaveThermostatModeConverter] - NODE 10: Generating message failed for command class = COMMAND_CLASS_THERMOSTAT_MODE, endpoint = 0
It’s working fine for me in OH3. The basic endpoint should be available.
I’m sending 0xFE to the ‘basic_basic_number’ endpoint:
Item:
Number  KitchenTrvThermostatBasic "Basic endpoint" {channel="zwave:device:65ff760b:node6:basic_basic_number"}
Rule:
logInfo("Kitchen", "Setting TRV to 'Manufacturer specific' mode")
KitchenTrvThermostatBasic.sendCommand(0xFE)
Then I control the TRV by sending the valve open % to the ‘switch_dimmer’ endpoint.
Dimmer KitchenTrvValvePosition "Kitchen TRV valve position"{channel="zwave:device:65ff760b:node6:switch_dimmer"}
KitchenTrvValvePosition.sendCommand(50.0)
You don’t have an old JAR lurking in your addons folder do you?
Or try deleting (NOT excluding from the network) & re-discovering the Thing in OH to be sure it has the latest settings from the binding.
I think I have cleaned up everything although I was migrating from 2.5 not reinstalling from scratch.
I recently was adding new Thing as it went in to locked state and I had to reset it to defaults as nothing else worked. After adding it as fresh it has Basic endpoint (rest of my old migrated things doesn’t have it - seems that starting from scratch would set up things properly).
Anyhow I tried with this channel here are the results:
2021-01-23 20:52:26.424 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'LucjaNode017Grzejnik_BasicDeprecated' received command 31
2021-01-23 20:52:26.447 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LucjaNode017Grzejnik_BasicDeprecated' predicted to become 31
2021-01-23 20:53:41.417 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'LucjaNode017Grzejnik_Dimmer' received command 50
2021-01-23 20:53:41.430 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LucjaNode017Grzejnik_Dimmer' predicted to become 50
2021-01-23 20:53:41.439 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LucjaNode017Grzejnik_Dimmer' changed from 0 to 50
2021-01-23 20:53:43.014 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LucjaNode017Grzejnik_Dimmer' changed from 50 to 0
This haven’t changed anything it was still in Heat mode.
Then I tried to send raw value
2021-01-23 20:55:59.775 [WARN ] [ule.handler.ItemCommandActionHandler] - Command '0xFE' is not valid for item 'LucjaNode017Grzejnik_BasicDeprecated'.
I’m using this new rules engine for experiments - not sure if this matters
firefox_2021-01-23_20-59-43
firefox_2021-01-23_21-03-04
@Morgano thanks for the tip I found the solution! When I went to old rules engine (application/vnd.openhab.dsl.rule)
And I did execute
LucjaNode017Grzejnik_BasicDeprecated.sendCommand(0xFE)
2021-01-23 21:06:51.273 [INFO ] [openhab.event.RuleUpdatedEvent      ] - Rule '150f3fa9a0' has been updated.
2021-01-23 21:06:56.286 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'LucjaNode017Grzejnik_BasicDeprecated' received command 254
2021-01-23 21:06:56.306 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LucjaNode017Grzejnik_BasicDeprecated' predicted to become 254
2021-01-23 21:06:56.319 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LucjaNode017Grzejnik_BasicDeprecated' changed from 31 to 254
Then dimmer started to work!
2021-01-23 21:07:55.521 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'LucjaNode017Grzejnik_Dimmer' received command 50.0
2021-01-23 21:07:55.534 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LucjaNode017Grzejnik_Dimmer' predicted to become 50.0
2021-01-23 21:07:55.545 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LucjaNode017Grzejnik_Dimmer' changed from 20 to 50.0
2021-01-23 21:07:57.197 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LucjaNode017Grzejnik_Currenttemperature' changed from 22.56 °C to 22.47 °C
2021-01-23 21:08:09.989 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'LucjaNode017Grzejnik_Dimmer' received command 21
Now that it works the question is did anyone implemented already any type of simple controller (kind of PID rule updated every X min). When I looked at implementations the actual PID regulators and started to think about one for heating is not as straight forward compared to usages when there is really quick change output values. With the room of size 12m2 setting up the dimmer to 100% will change the temp after 10min and then there is question how frequently to uptdate the dimmer.
@Dominik_Jeziorski There is a new experimental PID Controller available here:
I have used it on my TRVs and it is working really well. It uses the new GUI Rule Engine but will work in conjunction with Rules DSL rules. Read through the whole thread before doing anything.
I have set my PIDs to loop every 60s which may be too fast but I am still tweaking things at the moment.
Wow! Thanks.
Based on PID implementation I made tutorial how to use Spirits with manual mode - I hope that will be usable for others seeking solution for problems with those.
