EV Savings & Efficiency Widget
Description: This compact and intuitive widget visualizes the ecological and financial benefits of your EV charging. It translates your charging data into tangible savings by comparing your electric vehicle’s consumption against a traditional combustion engine.
Key Features:
  • Real-time Metrics: Automatically calculates the estimated range based on your specific EV consumption settings.
  • Smart Conversions: Calculates “Saved Fuel” (in Liters) by comparing EV charging (kWh) against a reference combustion engine consumption.
  • Configurable Parameters: Tailor the widget to your specific vehicle by defining your EV’s efficiency (kWh/100km) and your previous combustion engine’s efficiency (L/100km) directly in the UI.
  • Precise Feedback: Displays all values with one decimal place for higher accuracy in your daily monitoring.
  • Clean Design: Clean F7-card layout that fits perfectly into any energy-focused dashboard.
Configuration Parameters:
  • Last Charge (kWh): Item tracking the last charging session.
  • Total Charged (kWh): Item tracking the cumulative charging history.
  • EV Consumption (kWh/100km): Your electric vehicle’s efficiency.
  • Combustion Consumption (L/100km): Reference fuel consumption of your previous car.
Why use it? It provides immediate feedback on your transition to e-mobility, turning technical data (kWh) into easy-to-understand ecological savings (liters of fuel not burned).
Screenshots
Version 1.0
Resources
Code: ev_savings_widget.yaml
I think it should be noted that the number (“saving” etc.) is just fantasy. There are so many factors that decide how much a combustion engine consumes that anything you pick from a “reference table” has very little to do with anything. And, if you’re concerned with “carbon savings”, you should also factor in how the electricity you charge is produced.
But, I guess that to make you “feel good” it might be beneficial.
Well, I’m not concerned with CO2 savings. And thank you for worrying about how the energy is generated: in my case, the electric car is charged using surplus power.
Anyhow, I compared my specific consumption values for both vehicles based on my average driving profile. So I am not picking something from a “reference table”, don´t know what’s your point with this posting. Not everything has to be viewed from a scientific perspective. -But I am open to constructive suggestions for improvement.
