Events from WallMote Quad is not registered
Tags: #<Tag:0x00007fe740cca478> #<Tag:0x00007fe740cc9b68> #<Tag:0x00007fe740cc9848>
Dear Community,
I’ve been running into some problems with my WallMoteQUad (aeotec_ZW130). It was no fuzz to add it to “Things” and add the scenes to “Items”. However, when I push a button the only log entry I get is
“[vent.ItemStateChangedEvent] - ZWaveSerialController_StartFrames changed from 2438 to 2439” no matter which of the four buttons I press. This makes it a bit hard to create rules…
I’m also having trouble editing the configuration on the wallMote Quad. For example, I try to disable the touch sound, but it seems like the new settings aren’t uploaded to the wallMote Quad. I tried to push the action-button to send a wake up notification, but it just blinks orange for around 10 minutes. When I push the buttons, it still beeps and still, it seems like I’m not receiving any usefull information in openHAB.Here’s the log event that’s created when I save the changes:
[vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=config_1_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_2_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=config_4_1, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
I tried to remove the WallMote Quad several times. I also tried to remove and add the Z-Wave Serial Controller.
The WallMote Quad properties:
dbReference 535
defaultAssociations 1
manufacturerId 0086
manufacturerRef 0002:0082,0102:0082,0202:0082
modelId ZW130
vendor AEON Labs
zwave_beaming true
zwave_class_basic BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic GENERIC_TYPE_WALL_CONTROLLER
zwave_class_specific SPECIFIC_TYPE_BASIC_WALL_CONTROLLER
zwave_deviceid 130
zwave_devicetype 2
zwave_frequent false
zwave_listening false
zwave_manufacturer 134
zwave_neighbours
zwave_nodeid 8
zwave_routing true
zwave_secure true
zwave_version 1.8
Did I forget to do something important?
Best regards
Kristian the Rookie
  • P)latform information:
    • Hardware: Raspberry Pi 3b+ with a razberry card and 32 GB memory card
    • OS: OpenHABian v.1.4.1
    • Java Runtime Environment: _OpenJDK Runtime Environment (Zulu8.36.0.152-CA-linux_aarch32hf) (build 1.8.0_202-b152)
      OpenJDK Client VM (Zulu8.36.0.152-CA-linux_aarch32hf) (build 25.202-b152, mixed mode, Evaluation)
    • openHAB version: openhab2 2.4.0-1
@koverskeid You might want to tag this post with the zwave tag, as several people on the forum subscribe to that tag, hence there’s a greater chance one of them will see your post.
Also, there are several people on the forum using the Wallmote Quad (myself included), so we know it works. :smiley:
This is a report from the controller, which indicates there’s activity on the zwave network. This is ok, but doesn’t necessarily indicate anything good or bad with respect to the Wallmote.
A couple things to help level-set…
  • Is the Wallmote the only device in your zwave network? If there are other devices, are they working properly?
  • What are you using to manage your zwave devices? Paper UI? If so, I’d suggest you install the HABmin UI. It’s better for managing zwave devices. You can install HABmin using Paper UI.
  • I’d suggest you upgrade to the latest version of the zwave binding. You can do that by following the directions in this post. If you’re unfamiliar with the Karaf console, you can read about it here.
  • Debugging zwave issue can be tricky. There’s some good information about debugging here. At some point, we might ask for a debug log. But that’s a bit premature right now.
Hi Mark,
Thanks for the quick reply and good tips :slight_smile:
  • I have several other devices in my network:
    • Two HEATIT Z-TRM2fx that reports the temp and I can send commands to them
    • One FT112 door/window sensor that sends me updates if the door is open or closed
    • One DanalockV3 that worked fine yesterday, but after I reinstalled openhabian and updated the zwave binding, I can’t connect it
    • One ZXT-120 AC IR Remote that worked fine yesterday, but now I can only include it, not send
      commands.
    • Two Fibaro smoke sensors (FGSD-002-EN-A-v1.1) I can include, but no alarms are received (my
      ears are hurting after testing)
  • I tried to use HABmin, but weren’t that happy about it. See the next section :slight_smile:
  • After I updated the zwave binding from 2.4 to 2.5, I noticed some improvements. While I could change the settings on the wallmont quad (sound and vibration) from Paper UI (I was so happy), this didn’t work from HABmin. The wallmont quad seemed to receive the updates because it stopped blinking organge after I woke it up, but the sound and vibration settings didn’t change when I did it from HABmin. Another improvement was that I received scene changes when I pushed the different buttons, but if I pushed the same button twice, nothing was logged.
  • I have enabled debugging in case we have reached the point were you will ask me for a debug log :slight_smile:
I know a guy that has his smarthome set up, I will go to him to test if he can set up the wallmont quad properly at his place to check that it’s actually working.
I still haven’t figured out how to properly exclude things from OH and have a feeling maybe that’s why I can’t make the danalock and IR remote work properly. Is there any good procedure how to properly reset a thing to add it again as if it was brand new?
Hi aigan,
So I checked the debug log. When the wallmount quad was included securely, every time I pressed a button, I could see in the log that it was complaining about no valid nonce.
So I removed it and included it insecurely. Now I get a lot of lines in the debug log every time I press a button, but nothing when I turn off debug. The debug log is inlcuded under.
2019-05-06 20:19:51.740 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 04 15 05 5B 03 68 00 01 BF 00 6C
2019-05-06 20:19:51.775 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=21, callback=4, payload=04 15 05 5B 03 68 00 01 BF 00
2019-05-06 20:19:51.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=21, callback=4, payload=04 15 05 5B 03 68 00 01 BF 00
2019-05-06 20:19:51.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-05-06 20:19:51.785 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Application Command Request (ALIVE:STATIC_VALUES)
2019-05-06 20:19:51.789 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2019-05-06 20:19:51.791 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: SECURITY not supported
2019-05-06 20:19:51.795 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 21: Received COMMAND_CLASS_CENTRAL_SCENE V2 CENTRAL_SCENE_NOTIFICATION
2019-05-06 20:19:51.798 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 21: Received scene 1 at key 0 [Single Press]
2019-05-06 20:19:51.802 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2019-05-06 20:19:51.804 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=1.0
2019-05-06 20:19:51.809 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Updating channel state zwave:device:a7a53341:node21:scene_number to 1.0 [DecimalType]
2019-05-06 20:19:51.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Commands processed 1.
2019-05-06 20:19:51.817 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19cf5cd.
2019-05-06 20:19:51.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-05-06 20:19:51.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-05-06 20:19:51.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-05-06 20:19:51.831 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
That’s normal. With DEBUG turned off, there won’t be much in the log.
Always best to use code fences when posting debug logs. Much easier to read. :wink:
This looks fine. If you have an item linked to the scene_number channel, you should be able to deal with it in a rule like this.
rule "wallmote rule"
    Item Wallmote_Scene received update
    var double sceneNumber = (Wallmote1_Scene.state as Number).doubleValue
    switch (sceneNumber) {
        case 1.0 : {            // Button 1 short press
            // Do something
        case 1.1 : {           // Button 1 long press
            // Do something
        case 1.2 : {            // Button 1 hold
            // Do something
        // Repeat for buttons 2, 3, & 4
Hi Mark,
Once again, thank you very much for your tips and tricks :smiley:
I got the wallmote quad to work when I added the wallmote withouth encryption. Even made som nice rules that controlled my danalock.
However, when I’m adding it with encryption, it’s not recognized by my controller. I tried to add it in both HABmin and paperUI, but it doesn’t matter. I’m considering giving in and use it withouth encryption, but I want to try everything first because I intend to control a lock with it.
I guess a central clue is the error message “SECURITY_ERR No valid NONCE! null”
@koverskeid If you can provide a debug log starting from the point when you perform the secure inclusion, I’m sure @chris would be willing to take a look at what’s happening.
Sure - just mention me when posting it and I’ll take a look.
The best approach is to provide it as a linked file.
Thanks for the tip @chris, here are the log files from the discovery and inclusion process. When I added the wallmote quad (node 2), I woke it up at the same time.
openhab discovery.txt (91.4 KB)
openhab including.txt (4.7 KB)
It seems that the secure inclusion worked?
I appreciate it’s a little hard to see this image, but the secure key exchange seems to complete successfully. There are no errors that I can see in the inclusion log.
There is something strange in that it seems to try the key exchange again, but the device then sleeps so it doesn’t succeed anyway.
I’m very sorry @chris, but I didn’t notice that it was not included securely. Here is the log from me searching and including the wallmote quad securely as node 4. However, it doesn’t recognize it…
search and include securely.txt (28.9 KB)
