Example DSMR dutch smart meter (slimme meter)
Does somebody having a good working example for the DSMR dutch smart meter(slimme meter) binding.
I have a simple item and sitemap display but i also want some charts for the electricity and gas meter.
I would be very nice if somebody can post his items, sitemap and rules.
Thanks in advance.
Regards MIckel
Hi Mickel,
Items
Group chart ā€œā€ (All)
Number  P1_Actual_Delivery  "Huidig verbruik [%.1f kW]"  (P1,chart)    { dsmr="eActualDelivery" }
Number  P1_Actual_Production  "Huidig teruggeleverd [%.1f kW]"  (P1,chart)    { dsmr="eActualProduction" }
Sitemap
Frame label="P1 garafiek"{
	Text label="Grafiek P1" icon="kwhmeter" {
				Switch item=Weather_Chart_Period label="Chart Period" mappings=[0="Hour", 1="Day", 2="Week", 3="Month", 4="Year"]
				Chart item=chart period=h refresh=600 visibility=[Weather_Chart_Period==0]
				Chart item=chart  period=D refresh=900 visibility=[Weather_Chart_Period==1, Weather_Chart_Period=="NULL"]
				Chart item=chart  period=W refresh=3600 visibility=[Weather_Chart_Period==2]
				Chart item=chart  period=M refresh=3600 visibility=[Weather_Chart_Period==3]
				Chart item=chart  period=Y refresh=3600 visibility=[Weather_Chart_Period==4]
You should also add the following line in rr4dj.persist
// chart p1 meter
chart* : strategy = everyMinute, everyChange, restoreOnStartup
This works for me in OH 1.8.3
Items:
DateTime    P1_Timestamp           "Laatste meter lezing [%1$ta %1$tR]"            { dsmr="P1Timestamp" }
Number      P1_eDeliveryTariff1	   "Afgenomen stroom laagtarief [%.0f kWh]"        { dsmr="eDeliveryTariff1" }
Number      P1_eDeliveryTariff2	   "Afgenomen stroom hoogtarief [%.0f kWh]"        { dsmr="eDeliveryTariff2" }
Number      P1_eProductionTariff1  "Teruggeleverde stroom laagtarief [%.0f kWh]"   { dsmr="eProductionTariff1" }
Number      P1_eProductionTariff2  "Teruggeleverde stroom hoogtarief [%.0f kWh]"   { dsmr="eProductionTariff2" }
String      P1_eTariffIndicator    "Huidig tarief [MAP(dsmr.map):%s]"              { dsmr="eTariffIndicator" }
Number      P1_ActualDelivery      "Huidig afgenomen stroom [%.3f kW]"             { dsmr="eActualDelivery" }
Number      P1_eActualProduction   "Huidig teruggeleverde stroom [%.3f kW]"        { dsmr="eActualProduction" }
Number      P1_ePowerFailures      "Onderbrekingen in levering [%d]"               { dsmr="ePowerFailures" }
Number      P1_eLongPowerFailures  "Landurige onderbrekingen in levering [%d]"     { dsmr="eLongPowerFailures" }
Number      P1_eNumberOfLogEntries "Gelogde onderbrekingen [%d]"                   { dsmr="eNumberOfLogEntries" }
Number      P1_eInstantCurrentL1   "Huidige stroom [%.3f A]"                       { dsmr="eInstantCurrentL1" }
sitemap:
		Frame label="Electriciteitsmeter" {
			Text item=P1_Timestamp
			Text item=P1_eDeliveryTariff1
			Text item=P1_eDeliveryTariff2
			Text item=P1_eProductionTariff1
			Text item=P1_eProductionTariff2
			Text item=P1_eTariffIndicator
			Text item=P1_ActualDelivery
			Text item=P1_eActualProduction
			Text item=P1_ePowerFailures
			Text item=P1_eLongPowerFailures
			Text item=P1_eNumberOfLogEntries
			Text item=P1_eInstantCurrentL1
I’m not persisting the DSMR data directly, but rather combine it with the PV data to provide real consumption data etc.
can you post an example of the file dsmr.map?
I think this depends on your Smart Meter. My Kaifa MA105C sends
eTariffIndicator ā€˜0001’ for Laag/Nachttarief and ā€˜0002’ for Normaal/Hoogtarief
So a valid dsmr.map for this would be:
0001=Laag
0002=Normaal
Let me go one step back, how did you even get this working ? Did you connect a P1 kabel to your openhab host machine or use external device like plugwise or something ?
