First go here an/or here and/or here.
When it works from within python or running python from the login shell, we need to tweak things a bit in order to run it from a rule.
sendFBchatMsg.py:
#!/usr/bin/python
import sys
sys.path.append('/home/omr/.local/lib/python2.7/site-packages')
import fbchat
from fbchat import Client
from fbchat.models import *
thread_id = sys.argv[1]
if (len(sys.argv) > 3):
thread_type = ThreadType.GROUP
else:
thread_type = ThreadType.USER
chatMsg = sys.argv[2] # de-qoute string from OH2
if chatMsg.startswith('"') and chatMsg.endswith('"'):
chatMsg = chatMsg[1:-1]
#print "Params"
#print "argv1:", sys.argv[1]
#print "argv2:", sys.argv[2]
#print "chatMsg:", chatMsg
client = Client('<yourFBid>','<yourFBpassw>')
client.send(Message(text=chatMsg), thread_id=thread_id, thread_type=thread_type)
client.logout()
My ssh login on Ubuntu is /home/omr you must tune into yours.
Also, the path to /home/omr/.local/lib/python2.7/site-packages (where pip installs fbchat) needs to be
chown to openhab:youruser and chmod to +r & +x (all path items). This is because executeCommandLine from OH2 starts without much of an environment.
In OH2:
We want the uid to be globally available:
.items
String USERfbChatUid
String GROUPfbGroupChatUid
.rules
var String msg = "'System started. Stand by'" // note: double quoting!
var String msgGroup = "'System just restarted!'" // note: double quoting!
var String test = ""
rule "System start"
System started
logInfo("System", "System started (or a rule changed)");
USERfbChatUid.postUpdate("1234567...") // you must obtain your own uid
GROUPfbGroupChatUid.postUpdate("89101112...") // you must obtain your own uid
test = executeCommandLine("/usr/bin/python /home/omr/sendFBchatMsg.py " + USERfbChatUid.state.toString + " " + msg, 10000)
logInfo("fbchat", "sendFBchatMsg returned:" + test);
test = executeCommandLine("/usr/bin/python /home/omr/sendFBchatMsg.py " + GROUPfbGroupChatUid.state.toString + " " + msgGroup + " " + "GROUP", 10000)
This will trigger as soon as you save the rules file:
It is also possible to answer back from messenger back into OH2, but I leave that to the ones who need it.
