I suspect you use modbus2 binding?
I use modbus2 for another device (I do have an SMA solar inverter as well, but it´s not connected through modbus yet). I went for manual modbus config files, as it´s alot easier to handle. You can find my setup in this thread.
Basicly it should be the same connecting anything else using modbus2 binding, as long as you´ve got the modbus data for your inverter.
(When I get the time, I´ll try to figure how to add my SMA TPL6000 inverter through modbus as well, but I´m in no hurry, as I´ve got the SMA Energy Meter connected insted, which gives me the same detail the inverter can give me).
