I had created a way to apply policies to my kids devices on my firewall with this set up
But then needed a way to protect the sitemap from my kids being able to change the policies themselves.
Using this excellent example:
I stripped out what I didnt need and made a simple 4 number PIN access switch that I could drive visibility off of for sitemap items:
Items
Create a single line PIN code entry and a few items to show or store values
Number keypad "PIN" <lock>
Switch resetkeypad "Reset"
Switch keypadpass "PIN Correct"
String key1 "key1: [%s]"
String key2 "key2: [%s]"
String key3 "key3: [%s]"
String key4 "key4: [%s]"
String keycounter "keycounter: [%s]"
String keyentered "Key entered: [%s]"
Sitemap
Frame label="SecurityCode" {
Switch item=keypad icon="none" mappings=[1="1",2="2",3="3",4="4",5="5"]
Switch item=resetkeypad
Switch item=keypadpass
Text item=keyentered
Rule
var int key_digit_1 = 0
var int key_digit_2 = 0
var int key_digit_3 = 0
var int key_digit_4 = 0
var int key_count = 0
//Key Pad Code Comparison
rule "Key Digit"
Item keypad received command
//define correct keypad code here
var int code_1 = 1
var int code_2 = 2
var int code_3 = 3
var int code_4 = 2
//counter used for comparison of current keypad digit status to save the value in the correct variable
//will be reset after 5 digits have been entered - see below
if( key_count == 0) {
//read status of the keypad and write it to the variable
key_digit_1 = (keypad.state as DecimalType).intValue
key1.postUpdate(key_digit_1)
//counter +1 to allow entry of next number into other variable
key_count = key_count + 1
keycounter.postUpdate(key_count)
//display the just entered number in the updated text in the UI
keyentered.postUpdate(key_digit_1.toString + "-" + key_digit_2.toString + "-" + key_digit_3.toString + "-" + key_digit_4.toString)
else if (key_count == 1) {
key_digit_2 = (keypad.state as DecimalType).intValue
key2.postUpdate(key_digit_2)
keyentered.postUpdate(key_digit_1.toString + "-" + key_digit_2.toString + "-" + key_digit_3.toString + "-" + key_digit_4.toString )
else if (key_count == 2) {
key_digit_3 = (keypad.state as DecimalType).intValue
key3.postUpdate(key_digit_3)
else if (key_count == 3) {
key_digit_4 = (keypad.state as DecimalType).intValue
key4.postUpdate(key_digit_4)
//code comparison - if correct, trigger switch, reset variables, counter and displayed code
if( key_digit_1 == code_1 &&
key_digit_2 == code_2 &&
key_digit_3 == code_3 &&
key_digit_4 == code_4 )
keypadpass.sendCommand(ON)
key_count = 0
key_digit_1 = 0
key_digit_2 = 0
key_digit_3 = 0
key_digit_4 = 0
//if one of the code elements does not match, activate alarm system
else if(
key_digit_1 != code_1 ||
key_digit_2 != code_2 ||
key_digit_3 != code_3 ||
key_digit_4 != code_4) {
key_count = 0
key_digit_1 = 0
key_digit_2 = 0
key_digit_3 = 0
key_digit_4 = 0
keypadpass.sendCommand(OFF)
//manual switch to reset the keypad
rule "Key reset"
Item resetkeypad received command ON
key_count = 0
key_digit_1 = 0
key_digit_2 = 0
key_digit_3 = 0
key_digit_4 = 0
resetkeypad.sendCommand(OFF)
All you need to do then is wire up whatever you want “secured” using visibility tags
Frame label="Internet Access" visibility=[keypadpass==ON] {
Switch item=Policy_Jackson_Surface mappings=[block="Block",p_103="103",p_104="104"]
From any change of the “secured” items the rule that fires also resets the keypadpass state to OFF and everything is hidden again.
after youve finished testing remove the keypadpass switch from the sitemap
Limitations
- You cant have a PIN with the two of the same numbers following each other eg 1223
- The data entry can be sluggish, and sometimes posts the previous value
- If you flick the reset switch when the last number you have selected is the first number of the PIN (eg 1331) then you cant select the first digit again
Hope this helps someone.
