No idea about the refresh. I think a refresh interval is not yet
implemented, but better look into the source code to be sure. Will have a
look too some time this week. If not, this is definitely worth an issue for
HABPanel, as almost everything should refresh, IMHO.
I created a switch, a numeric and a datetime item per rule and update and evaluate the state in the rule. This way I can consistently keep track of the execution count and time and display it. I also want the ability to turn rules off via HabPanel, hence the switch.
Hello!
It is possible to make a custom widget that would show the state of the item as a dummy, but would be a button to navigate to another panel? In this case, the transition to another panel would be carried out only on this device?
Thank you for your help. I’m sure my English is very bad, so you did not understand my question. When switching to another panel, in your example, the transition will occur on all devices, and I need only on the current one. In standard widgets, there is a widget button, it has the action of switching to another panel, it’s very cool! But on this button you can place only the icon, and I need to display the status of the selected item.
Thank you!
Not sure about the second part but one way to do the first part would have the same panel configuration for each of your panels, but with a different Panel configuration name. It could be a real pain though, depending on how many panels you had, to modify something on all of them.
Yes, it’s not perfect yet, but it’s a start. The image widget unfortunately does not automatically resize the images. I’m sure this can be fixed using a custom image widget, but have not looked into that yet.
I just wanted to ask if anyone has done a satusbar for Kodi on the Habpanel…
And also for the buttons I wanted to add icons, I am familier with HTML and CSS, but what I wanted to do is to get the stock functions from the habpanel itself rather then rendering a mini page that displays a picture and sends a command
