Hi, I have Openhab 2 beta 4 install on a pi running rasbian (latest jessie, fully up to date). I’m also running oracle java 8 u101. Myopenhab works (albeit slowly at times). However i’m seeing the following error in the logs. Any ideas what is causing it?
2016-10-17 23:54:27.303 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Request method is GET
2016-10-17 23:54:27.309 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header referer = https://my.openhab.org/basicui/app?sitemap=home
2016-10-17 23:54:27.314 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header accept-language = en-GB,en-US;q=0.8,en;q=0.6
2016-10-17 23:54:27.319 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header host = my.openhab.org
2016-10-17 23:54:27.326 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header dnt = 1
2016-10-17 23:54:27.331 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header cache-control = no-cache
2016-10-17 23:54:27.336 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header accept-encoding = gzip, deflate, sdch, br
2016-10-17 23:54:27.342 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header accept = text/event-stream
2016-10-17 23:54:27.347 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty set header user-agent = openhab-cloud/0.0.1
2016-10-17 23:54:27.394 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Jetty finished receiving response header
2016-10-17 23:54:27.403 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Sent headers to request 1927
2016-10-17 23:54:27.408 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - {"headers":{"Transfer-Encoding":"chunked","Server":"Jetty(9.2.14.v20151106)","Date":"Mon, 17 Oct 2016 22:54:27 GMT","Content-Type":"text/event-stream"},"responseStatusCode":200,"responseStatusText":"OK","id":1927}
2016-10-17 23:59:27.231 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - on(): cancel
2016-10-17 23:59:27.237 [DEBUG] [o.myopenhab.internal.MyOpenHABClient] - Received cancel for request 1927
2016-10-17 23:59:27.246 [WARN ] [o.myopenhab.internal.MyOpenHABClient] - Jetty request 1927 failed: null
2016-10-17 23:59:27.252 [INFO ] [clipse.jetty.client.ResponseNotifier] - Exception while notifying listener org.openhab.io.myopenhab.internal.MyOpenHABClient$ResponseListener@163053b
java.lang.NullPointerException
at org.openhab.io.myopenhab.internal.MyOpenHABClient$ResponseListener.onComplete(MyOpenHABClient.java:595)[202:org.openhab.io.myopenhab:2.0.0.b4]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:193)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:185)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:446)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpReceiver.abort(HttpReceiver.java:517)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpChannel.abortResponse(HttpChannel.java:129)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpChannel.abort(HttpChannel.java:122)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpExchange.abort(HttpExchange.java:257)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpConversation.abort(HttpConversation.java:141)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.eclipse.jetty.client.HttpRequest.abort(HttpRequest.java:704)[67:org.eclipse.jetty.client:9.2.14.v20151106]
at org.openhab.io.myopenhab.internal.MyOpenHABClient.handleCancelEvent(MyOpenHABClient.java:363)[202:org.openhab.io.myopenhab:2.0.0.b4]
at org.openhab.io.myopenhab.internal.MyOpenHABClient.onEvent(MyOpenHABClient.java:263)[202:org.openhab.io.myopenhab:2.0.0.b4]
at org.openhab.io.myopenhab.internal.MyOpenHABClient$6.call(MyOpenHABClient.java:196)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.emitter.Emitter.emit(Emitter.java:117)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Socket.onevent(Socket.java:317)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Socket.onpacket(Socket.java:280)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Socket.access$100(Socket.java:18)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Socket$2$2.call(Socket.java:101)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Manager.ondecoded(Manager.java:381)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Manager.access$1200(Manager.java:20)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Manager$3.call(Manager.java:355)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.parser.Parser$Decoder.add(Parser.java:156)[202:org.openhab.io.myopenhab:2.0.0.b4]
at io.socket.client.Manager.onda```
