2020-10-10 09:14:49.366 [WARN ] [org.apache.karaf.shell.ssh.Activator] - Exception caught while starting SSH server
java.net.SocketException: Operation not permitted
at sun.nio.ch.Net.listen(Native Method) ~[?:1.8.0_265]
at sun.nio.ch.AsynchronousServerSocketChannelImpl.bind(AsynchronousServerSocketChannelImpl.java:163) ~[?:1.8.0_265]
on my Raspberry on which I installed the Openhab snap today. At first I was getting address already in use on port 8080. After resolving that now I am getting this. I am not getting any specific port information in the logs.
Thanks for your response. Yes I found that file and tried changing the port and restarting but I am still getting the same error. Also, the error is different from the ‘address already in use’ which would have hinted to a port already in use issue.
However in my case, I am getting operation not permitted error. Ring any bells?
How did you install the software ( via openhabian-config or via repository installation ) ?
The startup is done by using systemctl command resp. reboot ?
