I am just starting out using OpenHAB. I have set up a batch file which echoes out the Java version, then start OpenHAB. I am using Win7.
Occasionally I get an exception as shown below:
Java setup -----------------
C:\OpenHAB>set JAVA_HOME=C:\OpenHAB\java
C:\OpenHAB>java\bin\java -version
openjdk version "11.0.14" 2022-01-18 LTS
OpenJDK Runtime Environment Zulu11.54+23-CA (build 11.0.14+9-LTS)
OpenJDK 64-Bit Server VM Zulu11.54+23-CA (build 11.0.14+9-LTS, mixed mode)
Launching the openHAB runtime...
_ _ _ ____
___ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 3.2.0 - Release Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
openhab> Exception in thread "Thread-15" java.lang.IllegalStateException: Executor has been shut down
at org.apache.sshd.common.util.ValidateUtils.createFormattedException(ValidateUtils.java:213)
at org.apache.sshd.common.util.ValidateUtils.throwIllegalStateException(ValidateUtils.java:207)
at org.apache.sshd.common.util.ValidateUtils.checkState(ValidateUtils.java:184)
at org.apache.sshd.common.util.threads.NoCloseExecutor.execute(NoCloseExecutor.java:100)
at java.base/sun.nio.ch.AsynchronousChannelGroupImpl.executeOnPooledThread(AsynchronousChannelGroupImpl.java:188)
at java.base/sun.nio.ch.Invoker.invokeIndirectly(Invoker.java:213)
at java.base/sun.nio.ch.Invoker.invokeIndirectly(Invoker.java:314)
at java.base/sun.nio.ch.WindowsAsynchronousServerSocketChannelImpl$AcceptTask.failed(WindowsAsynchronousServerSocketChannelImpl.java:286)
at java.base/sun.nio.ch.Iocp$EventHandlerTask.run(Iocp.java:389)
at java.base/java.lang.Thread.run(Thread.java:829)
I do not yet have any configuration done in OH.
Oh, and if I try to start it again, it works, and I have an OH command line prompt.
