I have a problem with my zwave device. The values are received correctly but then a callback exception is thrown. Can someone tell me what’s the problem here?
Other zwave devices work as expected. Openhab version 2.1.0
017-10-01 14:15:41.711 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-10-01 14:15:41.714 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 0A 06 31 05 01 0A 00 4B 8F
2017-10-01 14:15:41.717 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 0A 06 31 05 01 0A 00 4B 8F
2017-10-01 14:15:41.721 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0A 06 31 05 01 0A 00 4B
2017-10-01 14:15:41.723 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Application Command Request (ALIVE:DONE)
2017-10-01 14:15:41.725 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 10: Starting initialisation from DONE
2017-10-01 14:15:41.727 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1d4b448 already registered
2017-10-01 14:15:41.738 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 10: Incoming command class SENSOR_MULTILEVEL
2017-10-01 14:15:41.740 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5
2017-10-01 14:15:41.742 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Multi Level REPORT received
2017-10-01 14:15:41.757 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Type = Temperature(1), Scale = 1
2017-10-01 14:15:41.759 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 10: Sensor Value = 75
2017-10-01 14:15:41.760 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2017-10-01 14:15:41.761 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-10-01 14:15:41.763 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 75
2017-10-01 14:15:41.764 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 10: Sensor is reporting scale 1, requiring conversion to 0. Value is now 75.
2017-10-01 14:15:41.766 [DEBUG] [converter.ZWaveCommandClassConverter] - Converted temperature from 75F to 23.9C
2017-10-01 14:15:41.767 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Updating channel state zwave:device:15a670b08a0:node10:sensor_temperature to 23.9 [DecimalType]
2017-10-01 14:15:41.768 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.IllegalStateException: Could not update state, because callback is missing
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:267)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.ZWaveIncomingEvent(ZWaveThingHandler.java:1104)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:567)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveMultiLevelSensorCommandClass.handleApplicationCommandRequest(ZWaveMultiLevelSensorCommandClass.java:150)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:119)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:248)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:214)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:208)[189:org.openhab.binding.zwave:2.1.0]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1324)[189:org.openhab.binding.zwave:2.1.0]
