I have an issue with the Exec 2.0 Binding.
In PaperUI the Thing says “UNINITIALIZED - HANDLER_INITIALIZING_ERROR”
Here are my things (same error each):
exec:command:PixelController_PowerOn [command="sudo /home/pi/pixelcontroller/pixConServer/PixelControllerRPi.sh", interval=0, autorun=false]
exec:command:PixelController_PowerOff [command="sudo pkill -9 -f com.neophob.sematrix.cli.PixConDaemon", interval=0, autorun=false]
exec:command:PixelController [command="sudo /home/pi/pixelcontroller/pixConClient/PixConCli.sh -c %2$s", interval=0, autorun=true]
18:15:21.702 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'exec:command:PixelController_PowerOn' has been added.
18:15:21.717 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'exec:command:PixelController_PowerOn' changed from UNINITIALIZED to INITIALIZING
18:15:21.729 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'exec:command:PixelController_PowerOff' has been added.
18:15:21.739 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'exec:command:PixelController_PowerOn' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
18:15:21.736 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'exec:command:PixelController_PowerOn': java.lang.IllegalArgumentException
java.util.concurrent.ExecutionException: java.lang.IllegalArgumentException
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_111]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_111]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:186)[96:org.eclipse.smarthome.core:0.9.0.201612010841]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:79)[96:org.eclipse.smarthome.core:0.9.0.201612010841]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:63)[96:org.eclipse.smarthome.core:0.9.0.201612010841]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9.run(ThingManager.java:728)[103:org.eclipse.smarthome.core.thing:0.9.0.201612010841]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_111]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_111]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_111]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_111]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
Caused by: java.lang.IllegalArgumentException
at java.util.concurrent.ScheduledThreadPoolExecutor.scheduleWithFixedDelay(ScheduledThreadPoolExecutor.java:589)[:1.8.0_111]
at org.openhab.binding.exec.handler.ExecHandler.initialize(ExecHandler.java:105)[182:org.openhab.binding.exec:2.0.0.201612022359]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:731)[103:org.eclipse.smarthome.core.thing:0.9.0.201612010841]
at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)[103:org.eclipse.smarthome.core.thing:0.9.0.201612010841]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)[96:org.eclipse.smarthome.core:0.9.0.201612010841]
... 3 more
18:15:21.760 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'exec:command:PixelController_PowerOff' changed from UNINITIALIZED to INITIALIZING
18:15:21.769 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'exec:command:PixelController' has been added.
18:15:21.769 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'exec:command:PixelController_PowerOff' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
18:15:21.768 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'exec:command:PixelController_PowerOff': java.lang.IllegalArgumentException
... 3 more
18:15:21.808 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'exec:command:PixelController' changed from UNINITIALIZED to INITIALIZING
18:15:21.815 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'pixelcontroller.things'
18:15:21.822 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'exec:command:PixelController' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR)
18:15:21.821 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while initializing handler of thing 'exec:command:PixelController': java.lang.IllegalArgumentException
... 3 more
18:15:21.850 [WARN ] [home.core.thing.binding.ThingFactory] - Could not create channel 'run' for thing type 'exec:command:PixelController_PowerOn', because channel type 'exec:running' could not be found.
18:15:21.855 [WARN ] [.thing.internal.GenericThingProvider] - Could not create channel 'run' for thing 'exec:command:PixelController_PowerOn', because channel type 'exec:running' could not be found.
18:15:21.861 [WARN ] [home.core.thing.binding.ThingFactory] - Could not create channel 'run' for thing type 'exec:command:PixelController_PowerOff', because channel type 'exec:running' could not be found.
18:15:21.865 [WARN ] [.thing.internal.GenericThingProvider] - Could not create channel 'run' for thing 'exec:command:PixelController_PowerOff', because channel type 'exec:running' could not be found.
18:15:21.872 [WARN ] [home.core.thing.binding.ThingFactory] - Could not create channel 'run' for thing type 'exec:command:PixelController', because channel type 'exec:running' could not be found.
18:15:21.876 [WARN ] [.thing.internal.GenericThingProvider] - Could not create channel 'run' for thing 'exec:command:PixelController', because channel type 'exec:running' could not be found.
What is going wrong here?
