Exec-binding 2.0
I have a problem since the update of exec-binding.
With exec-binding 1.9 and openhab build 524 i could see executed commandLine … in log:tail when i switched on the button.
Now with exec-binding 2.0 and openhab build 624 with the same conf i don t see anything and my item has no action on the reality.
I guess that the module have a problem but in bundle:list i can see it. (193 | Active | 80 | 2.0.0.201611291735 | Exec Binding).
I m on MACOSX yosemith.
Have you got a solution ?
edit : With exec-binding 2.0, executeCommandLine is undefinned with Eclipse SmartHomeDesigner…
Regards,
YannF
Please post your Thing and Item definition
You can’t use the exec 2.0 binding exactly as you used the exec 1.9 binding. You need to read the documentation and adjust your config accordingly.
As far as I’m aware executeCommandLine isn’t part of the 2.0 binding.
For Rich:
blocks.items :
Switch test “Test” {exec=“>[ON:bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh t282-gude02 1 on] >[OFF:bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh t282-gude02 1 off]”}
This line works with exec binding 1.9 and openhab build 524
No file *.things
Openhab log show that exec command is captured
08:16:35.849 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘GUDESLOT1’ received command OFF
08:16:35.850 [INFO ] [marthome.event.ItemStateChangedEvent] - GUDESLOT1 changed from ON to OFF
08:16:35.852 [INFO ] [ab.binding.exec.internal.ExecBinding] - executed commandLine ‘bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh t282-gude02 1 off’
In exec binding 2.0 build 624 Openhab log just show button switch on or off,
08:12:54.662 [INFO ] [marthome.event.ItemStateChangedEvent] - test changed from ON to OFF
08:12:55.124 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘test’ received command ON
08:12:55.126 [INFO ] [marthome.event.ItemStateChangedEvent] - test changed from OFF to ON
08:12:55.696 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘test’ received command OFF
For Daniel :
Ok i will try to change my setting with a things declaration
Ok i understand the new system. But i have a problem :
Thing exec:command:gude [command=“bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh t282-gude02 1 on”]
Switch gude { channel=“exec:command:gude:run”}
Question :
Have you got example with a switch system ? I don’t understand how can i do as exec binding 1.9. I want to run my script with parameter on switch on, and other parameter on switch off.
Thank you
Hi Yann,
you can also add an argument to a command. Try this:
Thing exec:command:gude [command="bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh t282-gude02 1 %2$s", autorun=false]
%2$s will be replaced by your string
Item String gude { channel="exec:command:gude:input"}
Sitemap Switch item=gude label="Gude" mappings=[on="ON", off="OFF"]
Cheers
Thank you, It’s working but with a big delay.
When I click on the on or off button, there is 10-30 seconds of waiting time before action. With rules and exec command it’s immediately. Do you know why ?
Cheers
Edit : OK I have changed autorun false => true and it works.
But I don’t like the result, there is no update to the status (red or green), It’s not what i need.
In fact, I would like a switch which call a rule with 3 parameters (2 custom parameters and 1 which is the status of the switch : on or off).
Like this :
var status_on = " on"
var status_off = " off"
var gude001 =  " t282-gude02"
var port1 = " 1"
rule "gude001"
		Item t282gude02slot1 received command
		if(receivedCommand == OFF) executeCommandLine("bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh"+gude001+port1+status_off)
		if(receivedCommand == ON) executeCommandLine("bash /Users/name/Documents/openhab/conf/scripts/switchGudeStatus.sh"+gude001+port1+status_on)
Now i would like to do something like that :
*.items
Switch t282gude02slot1 {gude001=" t282-gude02"} , but i don’ know the syntax
Hi please help not working for me what am i doing wrong?
things.
Thing exec:command:micropcofft [command=“net rpc shutdown -I 10.0.0.10 -U gadof01%%123 -f”, interval=0, autorun=false]
items.
Switch mpcoff “MicroPc off” { channel=“exec:command:micropcofft:run” }
map.
Switch item=mpcoff
