HI All!
OH3, Exec binging 3.1.0, Raspberry Pi4, Buster.
Set up Exec binding to run external shell script on Item change.
Script gets executed, but OH says “process hasn’t exited - forcibly terminating process” in openhab.log
What is wrong here? Could anyone point me to right direction.
Thing declaration:
Thing exec:command:camera_lux_control [ command="/home/pi/scripts/camera/lux-control.sh %2$s", interval=0, timeout=0, autorun=false ]
Rule:
rule "Lightsensor changed - run uvcdynctl corrector script"
Item kitchen_lightsensor_lux changed
if (kitchen_lightsensor_lux.state < 200) {
var lux = kitchen_lightsensor_lux.state.toString
camera_lux_control_args.sendCommand(lux)
if (camera_lux_control_run.state != ON) {
camera_lux_control_run.sendCommand(ON)
else {
logInfo("camera_lux_control_run", "Script already in use, skipping execution.")
Items:
Switch camera_lux_control_run {channel="exec:command:camera_lux_control:run", autoupdate="false"}
String camera_lux_control_args {channel="exec:command:camera_lux_control:input"}
String camera_lux_control_out {channel="exec:command:camera_lux_control:output"}
Shell script is runnable by openhab. Moreover, script can be empty: it is empty at this moment - I commented out everything that could cause trouble (trying to catch problem inside the script). It is only:
#!/bin/bash
echo "TEST EXIT RES"
exit 0
It executes fine:
┌─[pi@pi162] - [~/scripts/camera] - [Вс ноя 14, 20:38]
└─[$] <git:(master*)> ls -al lux-control.sh
-rwxr-xr-x 1 pi openhab 1766 ноя 14 17:45 lux-control.sh
└─[$] <git:(master*)> sudo -u openhab ./lux-control.sh
TEST EXIT RES
┌─[pi@pi162] - [~/scripts/camera] - [Вс ноя 14, 20:39]
└─[$] <git:(master*)> echo $?
0
When script contains code, the code executes normally - logs from script are written, parameters are set - all is fine - no matter if it is run manually or by exec binding.
But every time it executes from OH Exec binding, OH generates errors. Sometimes one warning:
2021-11-14 20:05:27.517 [WARN ] [ng.exec.internal.handler.ExecHandler] - Forcibly termininating the process ('/home/pi/scripts/camera/lux-control.sh 3') after a timeout of 0 ms
Sometimes couple:
2021-11-14 20:12:40.574 [WARN ] [ng.exec.internal.handler.ExecHandler] - Forcibly termininating the process ('/home/pi/scripts/camera/lux-control.sh 2') after a timeout of 0 ms
2021-11-14 20:12:40.579 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalThreadStateException: process hasn't exited
at java.lang.ProcessImpl.exitValue(ProcessImpl.java:521) ~[?:?]
at org.openhab.binding.exec.internal.handler.ExecHandler.execute(ExecHandler.java:286) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
