Hi!
I have a shell script which retrieves weather data.
The script takes the type of data as parameter, e.g.:
To get the windspeed the script has to be called with parameter windspeed:
weather.sh windspeed
To get the winddirection the script has to be called with parameter winddirection :
weather.sh winddirection
As long as I have just one thing configured, everthing works fine.
Once I define two things which call one and the same script with different parameters it no longer works.
Things file:
Thing exec:command:weather_windspeed [command="/etc/openhab2/shellscripts/weather.sh windspeed", interval=60, timeout=5, autorun=false, transform="REGEX((.*?))]
Thing exec:command:weather_winddirection [command="/etc/openhab2/shellscripts/weather.sh winddirection", interval=60, timeout=5, autorun=false, transform="REGEX((.*?))]
Items file:
String Weather_Windspeed "Windgeschwindigkeit [%s km/h]" <wind> { channel="exec:command:weather_windspeed:output" }
String Weather_WindDirection "Windrichtung [%s]" <wind> { channel="exec:command:weather_winddirection:output" }
The openhab.log show the following warnings:
2017-04-21 22:04:14.168 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'exec.things'
2017-04-21 22:04:14.199 [WARN ] [.thing.internal.GenericThingProvider] - Thing sh does not have a bridge so it needs to be defined in full notation like <bindingId>:sh:winddirection
2017-04-21 22:04:14.214 [WARN ] [.thing.internal.GenericThingProvider] - Thing sh does not have a bridge so it needs to be defined in full notation like <bindingId>:sh:winddirection
2017-04-21 22:04:14.288 [WARN ] [.thing.internal.GenericThingProvider] - Thing sh does not have a bridge so it needs to be defined in full notation like <bindingId>:sh:winddirection
Thanks!
