tailor
(Christian)
October 29, 2017, 10:02am
1
I’m running OH on Ubuntu Intel NUC attached to a touchscreen. I’d like now to turn off the screen with a rule. Unfortunatelly it does not work.
Switch item for testing
Switch swi_turn_screen_off
rule
rule "Turn Screen Off"
Item swi_turn_screen_off changed to ON
executeCommandLine("xset dpms force off")
I also tried it with a separate sh file.
sh file (executable, /etc/openhab2/scripts/turnondisplay.sh):
#!/bin/bash
xset dpms force off
rule
rule "Turn Screen Off SH"
executeCommandLine("/etc/openhab2/scripts/turnondisplay.sh", 5000")
Log entries:
2017-10-29 10:58:32.184 [ItemCommandEvent ] - Item 'swi_turn_screen_off' received command ON
2017-10-29 10:58:32.186 [ItemStateChangedEvent ] - swi_turn_screen_off changed from OFF to ON
2017-10-29 10:58:32.191 [INFO ] [lipse.smarthome.io.net.exec.ExecUtil] - executed commandLine 'sh /etc/openhab2/scripts/screen_off.sh'
Has anyone an idea what’s going wrong? The script works if executed manually.
bkyle
(BK)
October 30, 2017, 2:34pm
2
Try without adding sh at the beginning and only doing
(“/etc/openhab2/scripts/screen_off.sh”)
Also make sure your sh file permissions are correct. When you run manually are you root or openhab user?
bennYx0x
(Benjamin)
October 30, 2017, 2:57pm
3
General hint for debugging:
Log the output of the execute like this:
val output = executeCommandLine("/etc/openhab2/scripts/screen_off.sh")
logInfo("Test", output)
That way you archieve more information about what is going wrong.
tailor
(Christian)
February 22, 2018, 8:37am
4
Thanks for your inputs! I’m using know a separate script file and a rule:
#!/bin/bash
xset dpms force off
rule
It works now theoretically. Unfortunatelly there’s an issue with the users.
Openhab runs with the user “openhab”. The current session showing HABpanel runs with the user “viewer”.
The script ends with the following message:
unable to open display
This makes sense because the openhab user runs just the openhab service …
Any ideas or workarounds?
tailor
(Christian)
February 22, 2018, 5:43pm
5
it works now with the following command:
sudo -i -u viewer xset -display ":0" dpms force off
So the openhab users switches to the user “viewer” owning the display session.
I needed to add the user openhab ALL=NOPASSWD: ALL to visudo.
Is it possible to allow openhab only executing the above sudo command? In my opinion it’s not really a specific command like “systemctl” … so it’s not as easy to restrict, is it?
Josar
(Josar)
February 22, 2018, 8:19pm
6
There are situations where you want to use the Exec Binding to trigger something. Sometimes you need the sudo privilege to do this. I would rather try some group specification to reduce the user rights to a minimum, but here is how i got openHAB to be able to execute sudo.
Try executing a command as openhab
sudo -u openhab sudo -l
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of other…
Idea 1: So basically make a script that has the command and set this to visudo.
Idea 2: Ebable the user openhab to access the xserver. Not tested but found in German forum .
Only works till reboot.
xhost +si:localuser:openhab
Set this to the file .xsessionrc for permanent rights.
