i have the exec-binding working. and i tigger a sh-script with it.
the sh script schould write the Temp of CPU to a item.
How does i make this? echo to item?
thank you for help
Use sendCommand.
FamilyFan.sendCommand(ON)
Yes, echo to stdout. The output channel will then set the item.
String Vuduo_Info "Curently running: [%s]" <tv> (VUDUO) ["Status"] {channel="exec:command:vuduoinfo:output"}
