One of my exec things has a strange behavior. After a certain time (usually several days, sometimes weeks) it isn’t updated automatically as usually. But I can trigger it manually. Also running the command from the console is working without problems.
In the logs below you can see that the last run according to the interval was at 05:23:10 and it received no output.
After this point the command is only executed when the channel ‘run’ is set to ON (in my program every 6 minutes). That’s a workaround to get the data even when the misbehavior occurs.
The wanted behavior can be restored by reloading of the thing file.
I had this behavior since a very long time (with OH 2.x on older Pi and also now with 3.2.0.M1 on Pi 4). But now I’m looking for a solution to get rid of it.
Thing exec:command:execBLNetQuery "execBLNetAbfrage" @ "logical"
command="/usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null",
interval=30,
timeout=15,
autorun=false
2021-09-07 05:20:08.934 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:20:08.935 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:20:08.935 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:20:08.973 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:20:08; 89.3; 47.9; 47.8; 88.4; 27.1; 27.2; 45.9; 4.9; 86.3; 9.8; 24.9; 26.0; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:20:08.974 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.3:47.9:47.8:88.4:27.1:27.2:45.9:4.9:86.3:9.8:24.9:26.0:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:20:08.979 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:20:08; 89.3; 47.9; 47.8; 88.4; 27.1; 27.2; 45.9; 4.9; 86.3; 9.8; 24.9; 26.0; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:20:38.981 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:20:38.981 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:20:38.981 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:20:39.019 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:20:39; 89.4; 47.9; 47.8; 88.3; 27.2; 27.2; 45.9; 4.8; 86.3; 9.7; 24.8; 26.0; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:20:39.019 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.4:47.9:47.8:88.3:27.2:27.2:45.9:4.8:86.3:9.7:24.8:26.0:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:20:39.023 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:20:39; 89.4; 47.9; 47.8; 88.3; 27.2; 27.2; 45.9; 4.8; 86.3; 9.7; 24.8; 26.0; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:21:09.972 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:21:09.973 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:21:09.973 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:21:10.011 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:21:10; 89.4; 47.9; 47.8; 88.3; 27.3; 27.2; 45.9; 4.8; 86.3; 9.7; 24.9; 25.9; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:21:10.011 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.4:47.9:47.8:88.3:27.3:27.2:45.9:4.8:86.3:9.7:24.9:25.9:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:21:10.016 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:21:10; 89.4; 47.9; 47.8; 88.3; 27.3; 27.2; 45.9; 4.8; 86.3; 9.7; 24.9; 25.9; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:21:40.017 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:21:40.017 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:21:40.017 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:21:40.055 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:21:40; 89.3; 47.9; 47.8; 88.3; 27.1; 27.3; 46.0; 4.8; 86.3; 9.7; 24.9; 25.9; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:21:40.055 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.3:47.9:47.8:88.3:27.1:27.3:46.0:4.8:86.3:9.7:24.9:25.9:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:21:40.058 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:21:40; 89.3; 47.9; 47.8; 88.3; 27.1; 27.3; 46.0; 4.8; 86.3; 9.7; 24.9; 25.9; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:22:10.297 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:22:10.297 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:22:10.297 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:22:10.333 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:22:10; 89.3; 47.9; 47.8; 88.4; 27.1; 27.2; 46.4; 4.9; 86.3; 9.8; 25.0; 25.7; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:22:10.334 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.3:47.9:47.8:88.4:27.1:27.2:46.4:4.9:86.3:9.8:25.0:25.7:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:22:10.341 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:22:10; 89.3; 47.9; 47.8; 88.4; 27.1; 27.2; 46.4; 4.9; 86.3; 9.8; 25.0; 25.7; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:22:40.342 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:22:40.343 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:22:40.343 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:22:40.383 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:22:40; 89.4; 47.9; 47.9; 88.3; 27.1; 27.2; 46.8; 4.9; 86.2; 9.7; 24.9; 25.7; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:22:40.384 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.4:47.9:47.9:88.3:27.1:27.2:46.8:4.9:86.2:9.7:24.9:25.7:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:22:40.390 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:22:40; 89.4; 47.9; 47.9; 88.3; 27.1; 27.2; 46.8; 4.9; 86.2; 9.7; 24.9; 25.7; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:23:10.937 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:23:10.937 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:23:10.937 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:28:01.488 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:28:01.488 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:28:01.488 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:28:01.532 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:28:01; 89.4; 50.7; 48.1; 88.3; 27.3; 27.3; 48.5; 4.8; 86.3; 9.6; 24.8; 25.2; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:28:01.532 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.4:50.7:48.1:88.3:27.3:27.3:48.5:4.8:86.3:9.6:24.8:25.2:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:1:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:28:01.537 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:28:01; 89.4; 50.7; 48.1; 88.3; 27.3; 27.3; 48.5; 4.8; 86.3; 9.6; 24.8; 25.2; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:34:02.021 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:34:02.022 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:34:02.022 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:34:02.057 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:34:02; 89.3; 51.6; 48.0; 88.3; 27.2; 27.3; 48.2; 4.7; 86.3; 9.6; 25.6; 25.0; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:34:02.058 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.3:51.6:48.0:88.3:27.2:27.3:48.2:4.7:86.3:9.6:25.6:25.0:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:1:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:34:02.065 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:34:02; 89.3; 51.6; 48.0; 88.3; 27.2; 27.3; 48.2; 4.7; 86.3; 9.6; 25.6; 25.0; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
2021-09-07 05:40:02.189 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Passing to shell for parsing command.
2021-09-07 05:40:02.189 [DEBUG] [ng.exec.internal.handler.ExecHandler] - OS: *NIX (Linux)
2021-09-07 05:40:02.189 [TRACE] [ng.exec.internal.handler.ExecHandler] - The command to be executed will be '[sh, -c, /usr/local/bin/dl-aktuelle-datenx -i 192.168.44.11 -t 0 --rrd 2> /dev/null]'
2021-09-07 05:40:02.225 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '07.09.21;05:40:02; 89.3; 51.9; 48.0; 88.3; 27.2; 27.3; 48.2; 4.6; 86.2; 9.6; 27.7; 30.6; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;'
2021-09-07 05:40:02.226 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Exec [OUTPUT]: '89.3:51.9:48.0:88.3:27.2:27.3:48.2:4.6:86.2:9.6:27.7:30.6:409.5:-409.6:0.0:51.1:0:0:0:0:1:0:1:0:0:0:0:0:0:0:0:0:0:0.0:0:0.0:0:0'
2021-09-07 05:40:02.231 [DEBUG] [ng.exec.internal.handler.ExecHandler] - Transformed response is '07.09.21;05:40:02; 89.3; 51.9; 48.0; 88.3; 27.2; 27.3; 48.2; 4.6; 86.2; 9.6; 27.7; 30.6; 409.5; -409.6; 0.0; 51.1; 0; 0; 0; 0; 1; 0; 1; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0.0;00.0; ---; ---;
runtimeInfo:
version: 3.2.0.M1
buildString: Milestone Build
locale: de-DE
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.11
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.48+21-CA
osName: Linux
osVersion: 5.10.60-v8+
osArchitecture: aarch64
availableProcessors: 4
freeMemory: 39994808
totalMemory: 283115520
