I have just migrated and copied 1:1 that file from SD-Card and “uploaded” it via Portainer-Agent into the volume.
But still get (already restarted containers)
The permissions look fine. All I can think of is to verify that user openhab from that ls command is the same uid as openHAB is running as inside the container (that looks like an ls from inside the container but you don’t say).
All I can recommend is to verify that the line exactly matches that command and to verify that some hidden character didn’t get added during the copy or something like that.
Since it’s a simple curl, is there a reason for not using the HTTP binding in the first place?
UID: http:url:awsiop
label: Amazon AWS IP
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: https://checkip.amazonaws.com
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
timeout: 3000
bufferSize: 2048
channels:
- id: last-failure
channelTypeUID: http:request-date-time
label: Last Failure
configuration: {}
- id: last-success
label: Last Success
configuration: {}
- id: IP
channelTypeUID: http:string
label: IP Address
description: ""
configuration: {}
But now I have a crazy sideeffekt during editing “Code” of Thing:
UID: http:url:checkip_amazonaws_com
label: WAN IP
configuration:
authMode: BASIC
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
timeout: 3000
bufferSize: 2048
channels:
- id: IP
channelTypeUID: null
label: null
description: null
configuration: {}
- id: checkip_amazonaws_com_ip
label: IP
description: ""
configuration:
mode: READONLY
- id: checkip_amazonaws_com_last-success
channelTypeUID: http:datetime
label: Letzter Erfolg
description: ""
configuration: {}
Do you see the Block with “null”? That was created (and will not leave ) since I pasted your block (starting with “channels”)
Direkly after pressing save (with no channels at all) this with “IP” appeared and the other two dissappeared
Finally I added two (s.o.) within the GUI. (Never had such Problems with that Code-Tab; Migrated at least 15 Thinks like this from one OpenHab to another)
I dont know why and I don’t know how to remove (workarround might be removing whole Thing)
Any Idea (before I remove this broken stuff)?
