Execute command line script (with SQL statement inside) from OH3 docker
am in the middle of migration to OH3. After searching 4 days in the forum, I got a lot closer - but do not get this to work. To pull data from my remote SQL data base I have a script that provides items and things from my SBFspot database. Later I also want to use scripts to write specific data into mySQL.
Environment:
  • Ubuntu server 21.04
  • Openhab 3.1.0 as docker (standard configuration)
  • On my server (not as docker): mySQL Server 8.0.25
I was able to call the script as root within Linux with result from my remote DB. So mySQL on the new machine also works.
I can call the script from a rule (conform to latest documentation):
var String test =  executeCommandLine(Duration.ofSeconds(10),"/openhab/conf/scripts/sma.script", "ETotal")
For testing my bash script (chown, whitelist, chgrp) I have included a simple textfile creation into the rule - to be shure it is executed :slight_smile: :
#!/bin/bash
user=openhab
password=mypassword
host=192.168.178.199
sql_name=$1
echo "Sql Name " $sql_name >> /openhab/conf/scripts/temp_output.txt
SMA_Val=$(mysql --defaults-extra-file=/openhab/conf/scripts/config.cnf  -N -e "select $sql_name from SBFspot.Inverters")
case "$sql_name" in
    EToday)     val=`echo "scale=2 ; $SMA_Val / 1000" | bc`;;
    ETotal)     val=`echo "scale=2 ; $SMA_Val / 1000" | bc`;;
    *)          val=$SMA_Val;;
esac
echo $val
And the text file gets created and filled
SQL Name  ETotal
As openhab executes inside the docker, my (fist) biggest issue was to find out - that the docker has different paths:
Host volume 	    Path in container
/opt/openhab/conf 	/openhab/conf
This is resolved. BUT in the log files show the following and I get no result from the sql statement:
2021-07-24 22:37:24.251 [INFO ] [.openhab.core.model.script.Test Exec] - /openhab/conf/scripts/sma.script: line XX: mysql: command not found
/openhab/conf/scripts/sma.script: line XY: bc: command not found
I guess the docker on sh command line cannot execute / interpret the mysql and bc!
My docker PATHs /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Is my assumption right, the sql engine is not found by the openhab docker?
Any suggestion how to fix this?
Or do I need to do a fresh install of OH3 without docker?
Thanks for any hint or advise.
Bernd
Yes, it looks like both commands are not installed in docker.
One possibility could be: https://stackoverflow.com/questions/32163955/how-to-run-shell-script-on-host-from-docker-container Although this is against the idea of having separation between guest and host.
Or create a new docker container that also includes bc and mysql client.
Thank you Wolfgang!
As I really want a clear and consistent setup… the solution to run scripts on host does not look preferred. This is mistreating the docker concept.
On the other hand: My docker skills to create my own Openhab3, mySQL and BC container are not sufficient… this I need to skip.
Unfortunately I have already 90% setup my OH3 in the docker… As there is no openhab-cli to backup for the docker. For those who also get stuck… This is how I managed.
  • Stop and remove OH3 docker
  • Install OH3 with apt-get as in documentation (install java 11 fist!)
  • Copy the folder content like cp -arv /opt/openhab/userdata/* /var/lib/openhab/ for:
  1. /opt/openhab/conf form Docker goes into /etc/openhab then all my textual defined items, things, rules, scripts, etc. are moved
  2. /opt/openhab/addons from Docker goes into /usr/share/openhab/addons then all additional addons are moved
  3. /opt/openhab/userdata from Docker goes into /var/lib/openhab then all Paper UI configuration is moved
Start your service systemctl start openhab.service and off you go!
Look at Executing shell scripts before openHAB is started in the Dockerhub readme.
Follow that to have the container execute a script that installs the MySQL client before it starts openHAB. You don’t have to create a custom Docker Image.
docker exec -it openhab runtime/bin/backup will do the equivalent to openhab-cli backup. However when one is running in a container, one usually mounts the config as volumes into the container and those volumes are backed up separately and independently from the container.
