Hey guys,
on my old openHAB 2.x installation I used executeCommandLine() in a rule and it worked without any problems.
For openHAB 3 I changed the path from /etc/openhab2/scripts/ to /etc/openhab/scripts/ :
rule "HarmonyHub - Apple TV, Netflix, Prime, Disney+ einschalten"
Item WohnzimmerHarmonyHubCurrentActivity changed to "AppleTV" or
Item WohnzimmerHarmonyHubCurrentActivity changed to "Netflix" or
Item WohnzimmerHarmonyHubCurrentActivity changed to "Amazon Video" or
Item WohnzimmerHarmonyHubCurrentActivity changed to "Disney+"
logInfo(filename, "Apple TV, Netflix, Amazon Prime oder Disney+ eingeschaltet")
executeCommandLine("/usr/bin/python /etc/openhab/scripts/dreamscreen.py -m 1")
Thread::sleep(500)
executeCommandLine("/usr/bin/python /etc/openhab/scripts/dreamscreen.py -s 0")
And I got the following error message:
2021-01-02 20:26:12.107 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Error occurred when executing commandLine '[/usr/bin/python /etc/openhab/scripts/dreamscreen.py, -m 1]'
java.io.IOException: Cannot run program "/usr/bin/python /etc/openhab/scripts/dreamscreen.py": error=2, Datei oder Verzeichnis nicht gefunden
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1128) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?]
at org.openhab.core.io.net.exec.ExecUtil.executeCommandLine(ExecUtil.java:59) [bundleFile:?]
at org.openhab.core.model.script.actions.Exec.executeCommandLine(Exec.java:40) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1176) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1151) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1137) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1082) [bundleFile:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:992) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:955) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:236) [bundleFile:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:216) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:459) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:240) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:202) [bundleFile:?]
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) [bundleFile:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:125) [bundleFile:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) [bundleFile:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:987) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
Caused by: java.io.IOException: error=2, Datei oder Verzeichnis nicht gefunden
at java.lang.ProcessImpl.forkAndExec(Native Method) ~[?:?]
at java.lang.ProcessImpl.<init>(ProcessImpl.java:340) ~[?:?]
at java.lang.ProcessImpl.start(ProcessImpl.java:271) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1107) ~[?:?]
... 35 more
The file is available, I can run the command directly via the command line.
Thank you
