executeCommandLine gives error - cannot bind 'local:5037'
I use this script for executing a shell
rule "dum2n"
		Item DebugSwitch4 received command ON
	then{
		val String results = executeCommandLine("/etc/openhab2/scripts/StartFireTV.sh", 5000)
		Basement_Fans.sendCommand(ON)
		logInfo("dum2n", results)
I get this error in the log
2018-03-18 12:03:22.605 [INFO ] [eclipse.smarthome.model.script.dum2n] - cannot bind ‘local:5037’
  • daemon not running. starting it now on port 5037 *
Any one have any idea what cause this problem?
rule "dum2n"
It looks like this error is coming from the StartFireTV.sh script instead of OpenHAB.
What is the output of the script when you run it manually?
[11:52:37] openhabian@openHABianPi:~$ /etc/openhab2/scripts/StartFireTV.sh
error: device not found
connected to 192.168.2.34:5555
However, it execute the script as it shall (it starts the fire-tv media player)
I updated the script, so it does not generate an error. I get a litle bit changed error in the log
2018-03-18 12:36:25.794 [INFO ] [eclipse.smarthome.model.script.dum2n] - ADB server didn’t ACK
  • failed to start daemon *
    error: cannot connect to daemon
Is dum2n a rule or a script what you start?
What’s the file-name?
My guess is that there is a problem with the rights. I think OpenHAB somehow has less rights while executing the script compared to running it directly via command line.
dum2n = rule
/etc/openhab2/scripts/StartFireTV.sh= script
I set the rigths to the script by using
sudo chmod a+rx /etc/openhab2/scripts/StartFireTV.sh
although I do not know if this gives sufficient rights
sudo rm /tmp/5037
fixed the problem!
