the return value is the full man page of the mysql command and instead of the result value.
2018-11-07 21:47:00.081 [INFO ] [lipse.smarthome.model.script.execute] - wert mysql Ver 15.1 Distrib 10.1.23-MariaDB, for debian-linux-gnueabihf (armv7l) using readline 5.2
Copyright (c) 2000, 2017, Oracle, MariaDB Corporation Ab and others.
Usage: mysql [OPTIONS] [database]
Default options are read from the following files in the given order:
/etc/my.cnf /etc/mysql/my.cnf ~/.my.cnf
The following groups are read: mysql client client-server client-mariadb
The following options may be given as the first argument:
--print-defaults Print the program argument list and e....
oh sorry, in the original console command line, the < was the correct “<” character, which I also used in the OH executeCommandLine call. It was somehow transformed by using the code fences.
As you bring it up, if this character is the problem, how would I have to escape it? I only read about spaces which have to be escaped by @@.
Is there a more comprehensive list of escape characters?
I think the escape character here is \ , e.g. to include a quote \"
I don’t know if that’s needed for <
Looking again at your post, I guess the // somehow got added as well? We probably ought to see the whole thing again. Not sure why you’ve got @@ in the timeout parameter.
What happens if you try some simpler sql query to begin with?
so here is the corrected code, simpler, now with direct sql command instead of a file link.
Also, -e causes a more readable error message:
var String T_a = executeCommandLine("mysql -h 192.168.2.180 -P 3307 -u openhab -popenhab -e \" USE openhab; SELECT samples.time , samples.value FROM samples WHERE samples.address = 4 Limit 1\" ", 1000)
logInfo("execute", " wert {} ", T_a)
This gives the following result:
2018-11-08 15:57:30.127 [INFO ] [lipse.smarthome.model.script.execute] - wert ERROR 1064 (42000) at line 1: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '"USE openhab; SELECT samples.time , samples.value FROM samples WHERE samples.a' at line 1
Using ’ or " as escape character does not change anything.
Appearantly, still something is wrong with the delimiter for the sql sequence.
Thus, both < and " make troubles and cannot be escaped, but I have no idea how to fix this.
I can get results by putting the whole commandline in a scriptfile:
