The Onkyo binding allows to send raw eISCP commands (https://community.openhab.org/t/onkyo-testers-for-thing-action-to-send-raw-eiscp-commands/68446)
This works in DSL as such (entire rule is slightly edited):
rule "Onkyo change radio frequency"
Item Onkyo_Radio_Frequency received command
val onkyoActions = getActions("onkyo","onkyo:TX-NR555:av1")
val radioFrequency = Onkyo_Radio_Frequency.state.toString
var transformedFrequency = radioFrequency.replace('.', '')
onkyoActions.sendRawCommand("TUN", transformedFrequency)
After reading:
https://crazyivan359.github.io/openhab-helper-libraries/Guides/Actions.html
and a few other posts in the forum I tried to replicate the above rule in jython but cannot seem to do so successfully. This is what I have:
@rule ("Onkyo change radio frequency")
@when ("Item Onkyo_Radio_Frequency received command")
def onkyoChangeRadioFrequency(event):
onkyoActions = actions.get("onkyo","onkyo:TX-NR555:av1")
radioFrequency = ir.getItem("Onkyo_Radio_Frequency").state.toString()
but I get an error: Undefined variable 'actions' for this line:
Also same error with: actions.get("onkyo","onkyo:TX-NR555:av1").sendRawCommand("TUN", transformedFrequency)
I also tried to import Onkyo: from core.actions import Onkyo however:
20:13:38.677 [ERROR] [ript.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/jsr223/python/personal/onkyo_avr.py': ImportError: cannot import name Onkyo in /etc/openhab/automation/jsr223/python/personal/onkyo_avr.py at line number 6
Just hoping there’s someone out there with some experience with this. I wonder whether I’m doing something wrong? Any suggestions gratefully received.
Running openHAB 3.2.0 Release Build.
