I am trying to understand why I am getting the following error in my logs:
2024-04-15 00:54:51.126 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'Kitchen_motion': Failed to execute action: 4(null)
Here is the code for action 4 that fails:
actions:
- inputs: {}
label: Update kitchen counter presence
description: Update dummy presence item
configuration:
itemName: KitchenCounterPresence
state: ON
type: core.ItemStateUpdateAction
- inputs: {}
label: send a log message (w Blockly)
configuration:
blockSource: <xml xmlns="https://developers.google.com/blockly/xml"><block
type="oh_log" id="5S;/bLIO+6nQU/)3]Tv$" x="260" y="162"><field
name="severity">info</field><value name="message"><shadow type="text"
id="ZP/|T$!=JK6/B5AHxG[Y"><field name="TEXT">abc</field></shadow><block
type="text_join" id="VEOl.NW/_=Rd3Vyt{t`E"><mutation
items="2"></mutation><value name="ADD0"><block type="text"
id="mSjb%m]IDES9V*ra=YUl"><field name="TEXT">Kitchen Counter occupancy
updated to ON, triggered by </field></block></value><value
name="ADD1"><block type="oh_context_info"
id="Z:vm-DP)e]}Y850P#O[b"><mutation asType="null"
contextInfo="itemName"></mutation><field
name="contextInfo">itemName</field></block></value></block></value></block></xml>
type: application/javascript
script: >
console.info(('Kitchen Counter occupancy updated to ON, triggered by ' +
String(event.itemName)));
type: script.ScriptAction
Why does this simple action fail?
