Oh yes sorry for not formatting the correct way, it was my first post.
It looks better now
Ok so if i only have:
var testmotion = executeCommandLine(Duration.ofSeconds(30), “python3”, “/etc/openhab/scripts/motionsensor.py”)
then I don’t see any output in logs.
And output of the
executeCommandLine(testmotion)
returns error from the first post.
I think that there is something wrong with the way that python3 is executed or maybe with permissions.
Because if i try:
val testmotion = executeCommandLine(Duration.ofSeconds(19), "python3", "/etc/openhab/scripts/motionsensor.py")
logInfo("test", testmotion)
I get this in the logs everytime script is executed.
2021-10-29 18:43:16.306 [INFO ] [org.openhab.core.model.script.test ] - Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: picamera in ./.local/lib/python3.7/site-packages (1.13)
and if i change try and except for loading module to just
from picamera import PiCamera
then everytime script is executed i get:
2021-10-29 18:45:26.063 [INFO ] [org.openhab.core.model.script.test ] - Traceback (most recent call last):
File "/etc/openhab/scripts/motionsensor.py", line 10, in <module>
ModuleNotFoundError: No module named 'picamera'
picamera module is installed with pip3
root@openhab:/etc/openhab/scripts# sudo -u openhab pip3 install picamera
Requirement already satisfied: picamera in /var/lib/openhab/.local/lib/python3.7/site-packages (1.13)
This is a very strange thing, because it seems like that picamera module is already installed for openhab user (which it is since it works ok if i run it as openhab user from shell). But on the other hand it cannot get loaded because there is no picamera module installed ?!?!?!’
So ok, I made a shell script that executes:
#!/bin/bash
whoami
/usr/bin/python3 /etc/openhab/scripts/motionsensor.py
and every time a get the same error in logs:
2021-10-29 19:14:45.102 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Error occurred when executing commandLine '[+ whoami
openhab
+ /usr/bin/python3 /etc/openhab/scripts/motionsensor.py
* failed to open vchiq instance
java.io.IOException: Cannot run program "+ whoami
openhab
": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1128) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?]
at org.openhab.core.io.net.exec.ExecUtil.executeCommandLine(ExecUtil.java:59) ~[?:?]
at org.openhab.core.model.script.actions.Exec.executeCommandLine(Exec.java:40) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1167) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1153) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:131) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1183) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:991) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:90) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.ProcessImpl.forkAndExec(Native Method) ~[?:?]
at java.lang.ProcessImpl.<init>(ProcessImpl.java:340) ~[?:?]
at java.lang.ProcessImpl.start(ProcessImpl.java:271) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1107) ~[?:?]
... 36 more
First i get * failed to open vchiq instance error which means openhab user is not in video group, but it is, because from shell it works ok and i have checked.
video:x:44:openhabian,openhab
And this error is also strange because it tells me that “rg.openhab.core.io.net.exec.ExecUtil” and java cannot run program “whoami” but then returns openhab, which is correct how it should be.
I bet there is something wring with permissions or with my installation of openhab.
Openhab is installed on RPI 3 with image file openhabian-pi-raspios32-v1.6.6.img.xz.
No docker container or anything.
