I started my journey to migrate from jython to python (HABApp).
Within the first parts is a buffer for messages, which are stored in a StringItem in order to use the persistence capabilities with RestoreOnStartup.
This buffer uses two simple functions to add and to remove the messages. These operations are locked with Lock().acquire()/release() as they run independently of each other.
Between the update of the StringItem and the availability as a new value is a certain time delay. In jython I’ve solved this wit a time.sleep(2) before the release of the lock. This works without any remarkable problems. The code is in no cyclic routine.
After migrating the code, HABApp warns about too long execution, which fills the log with the list of calls.
Therefor I have a couple of questions:
- is it possible to stop or reduce the output of these warnings about the execution time? Preferably just for this specific part of code?
- is it wise to postpone the call of Lock.release() with a run.at()? What would be the best way to do so?
- is there an alternative to the StringItem to use the persistence for the buffer? This could make all the above topics obsolete.
def AddMessageToBuffer(self, NewMessage):
Nachricht zum Buffer hinzufügen
LOGGER = "AddMessageToBuffer"
# Puffer wird hier bearbeitet - verriegeln
self.BufferLock.acquire()
try:
# ggf. Puffer zurücksetzen
Messages = self.BufferItem.value
if Messages is None:
Messages = ""
if Messages == "NULL":
Messages = ""
self.log.info(LOGGER + " old Buffer: {}".format(Messages))
# Nachricht an Puffer anhängen
# to be changed to use python concepts...
Messages = Messages + NewMessage # Nachricht
Messages = Messages + "%&%" # Endemarkierung
self.log.info(LOGGER + " new Buffer: {}".format(Messages))
# Puffer beschreiben
self.BufferItem.oh_post_update(Messages)
# verzögert. damit der String schon sicher intern verarbeitet ist
sleep(2)
except Exception as e:
self.log.error(LOGGER + " Error catched: {}".format(e))
self.log.info(LOGGER + " Message: {}".format(NewMessage))
finally:
# Puffer wieder freigeben
self.BufferLock.release()
# Bearbeitung der Nachricht anstoßen
self.BufferScheduler()
return
